Yet another set of brake calipers
Old Jul 12, 2019 | 02:42 PM
lantzd's Avatar
lantzd
Default Yet another set of brake calipers
So I am now going on my third set of brake calipers on my 05 SLT 4WD. First set of Power Stop calipers seized up, the send me a replacement set, now those have seized up. I am not messing with that brand anymore so I ordered coated ACDelco calipers with a new set of pads and new rotors. I also feel that with all my recent issues I am going to completely flush the old brake fluid out as it may have moisture in the fluid and could be contributing to my problems. Does anyone else find the Dodge caliper pad clips to be a poor design? I am paranoid now about pads resting on the rotors and I feel like the abutment clips are very difficult to get in place without bending them out of the stock position. Anyway, just wanted to vent to my fellow Dakota owners about my seemingly nonstop front brake issues. So far I have installed new brake lines, new calipers, new pads, new rotors. This time it will be all new DOT3 fluid, calipers, pads, and rotors. Lets hope I can get 50k miles out of this install.
Old Jul 13, 2019 | 07:03 AM
erau's Avatar
erau
Strange. I've never had caliper issues (still stock calipers) and I've never touched the fluid. Have been through 3 pad/rotor changes since new, and I believe all the new sets after factory OEM have been Raybestos.
Old Jul 13, 2019 | 07:57 AM
lantzd's Avatar
lantzd
I think my issues were initially moisture in the brake fluid. I noticed recently when adding brake fluid that there was a small tear in the rubber seal on the master cylinder cap. I think that is what seized up OEM calipers and since the fluid was never changed it was kept seizing the Power Stop calipers. I am getting a new cap for the master cylinder and doing a full fluid exchange. I cant imagine I will have more issues after doing all this so I hope it will all be worth it.
Old Jul 13, 2019 | 08:02 PM
philipat's Avatar
philipat
Sounds like the problem wasn't the Power Stop setup. Wonder how it would have worked out if the brake fluid was good...
Old Jul 14, 2019 | 06:07 PM
lantzd's Avatar
lantzd
Yes I initially thought the Power Stop brake calipers were the problem, I figured as far as rebuilt calipers, maybe they were not that reliable. I only went with them because they offered a powdercoated red option and it matched my truck and they were cheap. Only after replacing them twice did I notice the ever so slight tear in the rubber of the master cylinder cap. I will say this though, the Power Stop caliper piston boots did not last, they were all cracked and broken. This is likely due to them heating up from the stuck pads, but they were only on the truck for 8-10k miles. The ACDelco calipers I just got from Amazon build quality seem far superior as far as the rubber and pistons go.
Old Jul 14, 2019 | 06:13 PM
philipat's Avatar
philipat
Good to know. I had considered Power Stop as a future replacement (upgrade). I didn't realize that they are rebuilt calipers. I thought they were new and better quality. Glad to hear your comparison. Thanks.
Old Jul 14, 2019 | 06:19 PM
lantzd's Avatar
lantzd
Yea I really only went with them because they had the red powdercoated set. I did their drilled and slotted rotors as well but I haven't been too impressed with how they have been holding up. Granted they are not coated so its to be expected. This time around I got the Wagner coated rotors from RockAuto. Both the outer rim, outside hub and the inside hub that mates to the wheel bearing is coated black.
Old Jul 14, 2019 | 08:29 PM
Smokeykurt's Avatar
Smokeykurt
My calipers in my 05 are OEM and I haven't had an issue with them yet. ~crosses fingers~. Just did the front rotors/pads last year. When I was replacing my back brakes/cylinders, I decided to bleed all 4 brakes. Ended up having to replace the caliper bleeder screws on the front (they were rusted out). Aside from that though, they've been good.
Old Jul 21, 2019 | 10:58 PM
lantzd's Avatar
lantzd
So I finally got around to doing a full brake job. All new parts:
New master cylinder cap (OEM)
Front-Calipers (ACDelco), Rotors (Wagner Coated), Pads (Wagner OEX)
Rear-Cylinders (ACDelco), Drums (Wagner Coated), Shoes (Monroe), Spring Kit, Self Adjustment Kit
Did a full brake fluid change (Valvoline Synthetic Dot 3) as well and a proper brake bleed in correct order.
Lets hope this lasts for at least a year this time.
Old Jul 23, 2019 | 04:38 AM
philipat's Avatar
philipat
I hope it works out.
Did you replace the rear drums because they were Stop Power drums? Or, just because it was time?
