2006 3.7
Old Jul 27, 2019 | 04:14 PM
Tcat's Avatar
Tcat
Default 2006 3.7
Truck started overheatindand the guage got up to 3/4 mark and it started running rough. I changed thermostat and it is running at normal temp but wont idle and bucking.had a p305 code in 5.changed plugs and switched coil pack position.still wont idle but bucking stopped . Now i havepo172 code. Any advice?
Old Jul 27, 2019 | 06:58 PM
Jaded's Avatar
Jaded
Compression test would be next step if you have ruled out the ignition.
Old Aug 2, 2019 | 08:58 AM
superdak05's Avatar
superdak05
looks like bank 1 02 sensor might have crapped out, take a look under truck and see if any wires are touching exhaust, if not change them out. also depending on miles might be wise to change all of them.
