2005 Dakota codes
Old Jan 22, 2020 | 08:47 PM
Action70's Avatar
Action70
Default 2005 codes
need a starting point on Uncles 2005 4.7...it throws p0031 p0037 p0051 p0057...surely cant be all 4 o2 sensors at once
Old Jan 22, 2020 | 09:55 PM
dakotaff's Avatar
dakotaff
Check fuse 24. (Just a shot here.)
Old Jan 23, 2020 | 07:46 PM
Action70's Avatar
Action70
Default 2005 Dakota codes
Old Jan 25, 2020 | 08:14 AM
superdak05's Avatar
superdak05
i would start by looking at your catalytic convertor, one maybe plugged
Old Jan 29, 2020 | 02:52 PM
pierrejoly's Avatar
pierrejoly
try running a can of seafoam through the intake. i prefer the aerosol one through the throttle body, some prefer the liquid using a vacuum line.
either one will help clean the top of the valves, the top of the pistons and if clogged will help clean the catalytic converters. worked wonders for me when i was getting misfires and ended up clogging one of my cats.
Old Mar 8, 2020 | 11:16 PM
Action70's Avatar
Action70
thanks guys found the issue, traced it to wiring harness issue ...chafed wiring was culprit
Old Mar 8, 2020 | 11:17 PM
Action70's Avatar
Action70
thanks guys traced issue to so chafed wires in the harness
Old Mar 9, 2020 | 07:47 AM
Merged duplicate threads and closed since a solution was found.
