single chime upon startup
Old Jun 22, 2020 | 04:41 PM
rodslinger's Avatar
rodslinger
Originally Posted by dakotaff
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
Next time you start up, the 'chime' will be reset, and gone.
Have you tried this yet? Don't worry if you don't see the oil change indicator. Just try it to rule it out. Takes five seconds.
Old Jun 22, 2020 | 10:11 PM
mtnman82's Avatar
mtnman82
No I have not and yes I really need to try this. Been meaning to, will do and report back...
Edit: I did it and the extra chime went away! Looks like the mystery is solved - Thank you!
