how to actuate ASD relay?
Old Nov 22, 2020 | 06:58 PM
David Kalinowski's Avatar
David Kalinowski
Default how to actuate ASD relay?
So, I got the FSM from another post on this forum, and it has diagnostic steps for trouble shooting the codes I'm getting (P2302 and P301), but I dont think my code scanner can do what it telling me to. Its telling me to use a scan tool to actuate the asd relay.. I'm assuming there is a higher end scan tool that I need for this operation.. one that I do not have. Or is there a way to do this with out a scan tool?
Old Nov 22, 2020 | 07:29 PM
dakotaff's Avatar
dakotaff
The FSM is referring to dealer equipment, your scanner cannot help further, it will only read the code(s).
Switch coil 1 with another cylinder, and see if the issue goes with it.
Old Nov 23, 2020 | 09:24 AM
David Kalinowski
I figured that, coil one keeps exploding, I've been through 4 coils now. Its not just a miss fire, something else is going on (at least I believe there is). This is a picture of one of the coils that I took some time ago. https://drive.google.com/file/d/12R_...ew?usp=sharing and this https://drive.google.com/file/d/12JQ...ew?usp=sharing
Its being very consitent, its like the coil is being over charged or something. every thing else works as it should, radio, reverse, 4wd, etc.
Old Nov 24, 2020 | 07:08 AM
erau's Avatar
erau
Are you sure the spark plug is good? Using OEM coppers, right?
Old Nov 24, 2020 | 08:08 AM
David Kalinowski
Yea I put a new plug in. Champion.
Old Nov 24, 2020 | 09:01 AM
David Kalinowski
I've been asked to condense to a single thread. So I'm going to link back to my original thread. https://dodgeforum.com/forum/3rd-gen...oil-1-a-3.html
