My truck keeps blowing coil#1
P0301 points to a lot of things, but P2302 has much fewer potential suspects, so I would stick with that. You have already swapped the coil and PCM, so it isn't either of those. Which basically leaves the relay (which I don't think it is, otherwise you might see it on other cylinders, but hey, I'm wrong a lot), or the wiring for the coil, whether it's the hot lead or the control side of the wiring. Since it only affects one cylinder, it is quite likely that the problem is between the S117 splice and the coil. That's basically beside the cylinder 5 coil.
Of course, it could also be the connector that is cracked and/or shorting.
Diagnosing time.
Diagnosing time.
I have seen this particular issue before a few times, but, so far, no one has come up with a reason for WHY the coils are blowing up........
I'll try to get all the pertinent info together and create a mega thread a just post a link to that in the other threads. I found a video last night that has a guy trouble shooting this very issue, just on coil 7. I'm leaving towards a the control write is grounding out. But I need to get a test light tonight after work.
For any one interested I found this video. Nice trouble shooting on this very issue.
(The guy is also bi-lingual and repeats all instructions in spanish, which is awesome for people that are not english speakers.)
I have not gotten around to trying any thing else yet since my last update. Its been cold and getting dark early. But I'm off the rest of the week so I will be going at it tomarrow.
other than the whole thing exploding from the inside (like the inside epoxy melts, then the coil cracks open and it leaks out.) not that I can really see. I'll post a picture of the latest casualty when I get off work. (after 5pm central time)
Okay I have not gotten a test light yet, but I used my volt meter and the constant wire is reading solid 14.8 like it is supposed to, the interrupt wire never went below 6.5 volts, and fluctuated up to 10.5v Is it supposed to have a constant small charge or should it be 0 until needed?
Okay so I got the test light, it just flickered really fast on every coil I tested, so I then checked continuity and it was there, so as a last ditch effort I snipped the drive wire on from the ecm and from the plug, spliced in a new wire, moved the coil from cylnder 4 over to 1 and the only coffee being now is for cylinder 4 because there is no coil there. So after all this time it appears to have simply been a bad wire. I have to get a new coil tomorrow probably order it tonight so more like Monday or Tuesday, but I'll update more after that.
