no bus
Old Dec 24, 2005 | 01:55 AM
jerrya's Avatar
jerrya
Default no bus
2000 dakota 4.7 5 spd. I get a message on odometer of no bus. Truck wont start all dash lights and gauges work. Took a chance and install new computor with no help. Any suggestion greatly appeciated.
Old Dec 24, 2005 | 06:32 PM
DakotaStone's Avatar
DakotaStone
Default RE: no bus
Have it towed to Dodge and find out what the problem is. IF the truck won't start, then it's a good chance that the computer is bad.
Old Dec 25, 2005 | 02:14 AM
jerrya's Avatar
jerrya
Default RE: no bus
already put new computer in no help rather not bring to dodge someone has to experinced same problem.not much help on this board so far
Old Dec 28, 2005 | 01:37 AM
tenntech's Avatar
tenntech
Default RE: no bus
"No bus" means the communication system is down. These trucks have what is called a "can bus system", which consist of two wires that connect each module together through the front control module. If these wires are shorted, open, or grounded than it disrupts the communication. If the pcm cannot communicate to the skim module it doesn't know if the correct key is in the ignition, so it disables fuel. This system can be very difficult to diagnose, and it would probably be alot cheaper to take it to a dealer with a factory trained electrical master, than to guess.
Old Dec 28, 2005 | 02:55 PM
DakotaStone
Default RE: no bus
That's great info to know. Thanks for giving the info out.
Old Jan 1, 2006 | 05:19 PM
DAKZILA's Avatar
DAKZILA
Default RE: no bus
Had that happen to me. My crank shaft sensor wire got pinched between the block and bellhousing. It was my fault, I didn't check the wire before installing the motor. Anyway I found it by unpluging everything (injectors/sensors). I turned the truck on and the no bus wasn't there, so I plugged one in at a time and then turned the key on each time, until the no bus came back. The no bus came back on when I plugged the crank shaft sensor in. Well that's how I found my short.
Old Jan 2, 2006 | 05:54 AM
Silver HO's Avatar
Silver HO
Default RE: no bus
ORIGINAL: jerrya
I'd say if you just installed a new E.C.U. without programming it, thats the problem. It needs to be set up with the dealer's scan tool(DRB-3).
That goes for any engine,trans, or body E.C.U. on a newer car.
It would be nice if they were plug and play
