Nasty Plug
Old Jan 27, 2021 | 06:35 PM
hoot57's Avatar
hoot57
Default Nasty Plug
Recently got CEL. Scanner said p306. Cleared the code and bought new plugs. They all look fairly normal other than one, exhaust number 7 and was completely covered with crud. Runs okay but after going freeway speeds for several miles it will hesitate on take off from a stop. Time for new coil packs? TIA
Old Jan 28, 2021 | 07:48 AM
What plugs did you use?
Old Jan 28, 2021 | 08:56 AM
hoot57's Avatar
hoot57
I used NGK iridium plugs. I should have mentioned that it was doing the hesitating thing before I changed the plugs. I was hoping the new plugs would take care of the problem.
Old Jan 28, 2021 | 10:40 AM
These trucks prefer plain ol copper core plugs. Anything else, you are asking for trouble.
Old Jan 28, 2021 | 10:59 AM
dakotaff's Avatar
dakotaff
If you suspect a bad injector, swap it with another cylinder and see if the issue travels along with it.
Old Jan 28, 2021 | 11:03 AM
hoot57's Avatar
hoot57
The plugs I removed were the originals. They were iridium too. The truck only has 50k on it. It belonged to the Colorado Game and Parks. I think it spent it's whole life on dirt roads and never went over 45mph.
Old Jan 28, 2021 | 03:36 PM
superdak05's Avatar
superdak05
#6 misfire but plug 7 was covered? wondering since its never been beat if a valve is sticking, might want to do a seaform flush, put some high octane gas in it and run it up and down the highway also get a set of autolite 3922 plugs, these are a step cooler then stock, get rid of those iridiums .also those cats could possibly been clooged
Old Feb 7, 2021 | 08:35 PM
regg187's Avatar
regg187
Im sure the maintanence yard changed those plugs because copper is what they came with and what factory recommends for replacement!
Old Feb 8, 2021 | 07:57 AM
hoot57's Avatar
hoot57
All my research shows that the factory exhaust plugs were a Bosch Iridium plug. I'm thinking maybe I have a dirty injector.
This what my plug looked like!
Old Feb 8, 2021 | 10:22 AM
pilotsmack's Avatar
pilotsmack
What year is the truck? The original 4.7 manual has a big bold lettering saying to stick to copper plugs.
Not sure about the HO's, But we have seen this before on this forum,...
