Hi. recently a got the code p0344 so l buy one sensor for the cam. I did some test to test the wire (3), on the pin 1 l got nothing, on the pin 2 11.8V and on the pin 3 4.9V. Is it normal to see 0V on the pine 1 with the key on ? And l look online to find any wiring diagram to see where it goes but nothing (for the wire pin 1)
Hi l re check all my wiring and test my ground, did find out that l don't get voltage from the signal / return, while key on or when cranking. His there a fuse ? His the wire return directly l
For the information :The battery has bien change last year and for the sensor the guy at dodge tell my to by one at nappa because he can't have one by min 2 weeks
