Level Kit Installed!
Old Jun 10, 2006 | 07:54 PM
luvmydak's Avatar
luvmydak
Default RE: Level Kit Installed!
That's the look I want, but I'll probably have Meineke do it as I feel I don't have the expertise to do it properly. I have the tools minus a spring compressor but not the experience to do this. I don't start anything I can't finish.
Old Jun 10, 2006 | 08:56 PM
white26golf's Avatar
white26golf
You can use a C-clamp and a closed in wrench as a cheater pipe instead, if you're adventurous!
Old Jun 13, 2006 | 08:09 PM
gatruck's Avatar
gatruck
Well better late than never I guess... This is the now discontinued Performance Acc. level kit. I found it brand new on eBay for $70. Like I mentioned before it was pretty easy to install. I have had it on now for a month or so and no problems at all. The truck still sits with just a bit of rake but when I tow the boat (18' bay boat) it levels out nice.
I wish I had taken some before pics. Oh well..
Still saving some change for different tires. Btw, the truck white26golf posted also has the body lift...
Old Jun 30, 2006 | 01:35 PM
white26golf
Has anyone else done this? Did you notice a difference, It doesn't look that different in the pictures, I am thinking about doing this. I have found a different kit other than the performance acc.'s one. Just want to know if it is going to be worth the 70 bucks.
Old Jun 30, 2006 | 01:54 PM
luvmydak's Avatar
luvmydak
I thought about it for a while and decided not to. I don't feel it looks any different. It's a lot of work and I think you really have to know what you're doing. If you are confident about doing it yourself, go for it.
Old Jun 30, 2006 | 06:22 PM
superdak05's Avatar
superdak05
i installed the lowering shakles instead. looks a lot nicer with the wheel wells sitting even then with the *** end up in the air. i have noticed a difference while cornering now. seems smoother it does not dive into the corners.
Old Jul 1, 2006 | 01:55 AM
Chad05's Avatar
Chad05
what is a leveling kit and lowering shakles and why would you want the *** end high and not the front and back leveled out, just get a lowering kit or a lift kit, why would want to level the truck, they are already factory leveled or dont i know something, and the pic of the gray dakota, what are talking about, you can definitely tell that that truck was lifted.
