Any Ideas?
Old Jun 8, 2006 | 12:06 PM
tasmanohio's Avatar
tasmanohio
Default Any Ideas?
I just put the 20"s on now when i am comming to a stop my truck shakes till i am stopped. I have drove on the eway and rides fine. So its just when i am stopping. Any ideas?
Old Jun 8, 2006 | 12:48 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: Any Ideas?
Could be that your rotors are warped, brakes are bad, combination of the two. Changing wheel sizes like you did.....can actually fry the old rotors/brakes fairly quickly.
I'd check those two items out first.....
Old Jun 8, 2006 | 01:02 PM
sdsdsd's Avatar
sdsdsd
Very important tighten lug nuts to manufactures specs so rotors don't warp.
Old Jun 8, 2006 | 01:10 PM
DevilsReject
Noob Assassin
ORIGINAL: sdsdsd
Ooooo good point, forgot to mention that. Often times, tire/wheel shops will over torque the lug nuts down when putting the wheels on. This will lead to possible warping of rotors & possible inability to remove a flat tire, (I couldnt remove my lugnuts when trying to change my brakes/rotors).
Definitely know the torque specs on your lugs and if necessary, keep a torque wrench handy...
Old Jun 8, 2006 | 01:21 PM
tasmanohio's Avatar
tasmanohio
i really hope that tireman didnt mess up my rotors. You think that the warr. would cover that? Truck only has 120 miles on it
Old Jun 8, 2006 | 03:07 PM
dodgedlr's Avatar
dodgedlr
ORIGINAL: tasmanohio. You think that the warr. would cover that? Truck only has 120 miles on it
Tough call...
But the first thing I thought of was the rotors. We ran into that a few times here. Loosen the lug nuts and retighten with a torque wrench to 95 ft. lbs. Should come out of it...if not use a dial indicator to measure the runout of the rotors for warpage.
Old Jun 8, 2006 | 07:57 PM
tasmanohio's Avatar
tasmanohio
So i took off the front wheels and retorqued them. Same problem but not as bad. I am going to have to put factory wheels back on and set an apt. with dealer for new rotors.
Old Jun 11, 2006 | 10:16 AM
dueler320's Avatar
dueler320
If you check some of the formal complaints for the new Dakotas, there is a known random problem about shuddering when breaking, it has thrown engineers for a loop. I have only seen one person say that their deler got it fixed by replacing the axle and brakes. My Dakota has a very slight one, but not worth bothering with.
Old Jun 12, 2006 | 04:20 AM
Chad05's Avatar
Chad05
Hey that shuddering when breaking thing, can you feel it in the steering wheel and does it seem to be on certian roads.
Old Jun 12, 2006 | 10:10 PM
snobrdrdan's Avatar
snobrdrdan
I said this in a different post for a guy that put 22's on his truck.....
Do you not understand that the new wheels weigh A LOT more than the stock wheels?? It's all about rotating mass & the new wheels are gonna eat up your brakes.
When you put bigger wheels on a car/truck, you need to have good brakes to slow all that moving weight down. The Dakota's brakes suck already (really bad) & putting bigger wheels on is just gonna make them worse.
So while you already spent $1,000-2,000 on the wheels/tires so your truck might look cool parked.......it's gonna slow you down, give you worse gas mileage, & hurt you in the wallet when you have to keep replacing the brakes
Doesn't seem worth it to me, but whatever floats your boat
Brakes aren't covered under the full factory warranty either....it's only the first year/12,000 miles (I believe)
