Question re 4x4
Old Sep 11, 2006 | 10:08 PM
Seinatra's Avatar
Seinatra
Default Question re 4x4
Hello all, new to the forum. I have a question about the 4x4 shifting on a 2005 Dakota. There is a small **** to turn to 4Lock and 4lo. I assume 4lock is the normal gear to put it in for 4x4. Is this correct? My truck does not have a manual. Thanks.
Old Sep 11, 2006 | 10:17 PM
jnellydodge's Avatar
jnellydodge
Default RE: Question re 4x4
Yes, 4 Lock= 4 hi
Old Sep 11, 2006 | 10:23 PM
Seinatra's Avatar
Seinatra
Ok, thanks much for the quick response.
Old Sep 11, 2006 | 10:26 PM
superdak05's Avatar
superdak05
becarefull when switching the **** into 4 hi. while driving. i think the max speed is 30 mph. before turning ****. dont think you can switch while driving at highway speeds.
Old Sep 11, 2006 | 10:54 PM
turbot_bird's Avatar
turbot_bird
I thought you could do the shift on the fly transfer cases at any reasonable speed?
Old Sep 12, 2006 | 12:43 PM
Seinatra's Avatar
Seinatra
Is it normal for the truck to kind of 'drag' at low speeds in 4x4? Seems like its really fighting to keep moving when going through a parking lot, or turning for example. Drag is not the right word, but just feels clunky. My last vehicles with full 4x4 were jeeps and had the full-time 4x4 so I dont know if this is normal.
Old Sep 12, 2006 | 01:32 PM
turbot_bird
your not sappost to put it in 4x4 on hard surfaces like pavement because the tires want to turn at the same speed but cant when turning on pavement
Old Sep 12, 2006 | 09:23 PM
ptschett's Avatar
ptschett
You can turn the 4x4 **** from 2wd to 4x4 high at any speed, but you have to drop to or below 55 MPH before the computer lets the shift occur. Once it's engaged you can exceed 55 again.
Bad handling, tire scrub, etc are normal with a locked transfer case on dry hard surfaced roads. When you're turning, each tire wants to rotate at a different speed, because each tire follows a different path around the turn; this causes the front and rear axles to want to be rotating at different speeds. 4wd makes both axles turn at the same speed, causing the weird handling. You're best off to leave it in 2wd (w/ part-time TC) or AWD (w/ full-time TC) and shifting only when needed (for ice/snow/sleet, mud/off-roading, etc.)
Old Sep 13, 2006 | 01:05 AM
superdak05's Avatar
superdak05
thats good, 55 or under. my full size had the lever you had to pull, aqnything over 30 mph and it would bang and clank while trying to go into 4 hi
Old Sep 13, 2006 | 02:54 PM
Seinatra's Avatar
Seinatra
Thanks everyone for the help!
