CAI
Old Sep 18, 2006 | 05:04 PM
Mantis's Avatar
Mantis
Default CAI
It
Old Sep 18, 2006 | 05:46 PM
bkjtimp's Avatar
bkjtimp
Default RE: CAI , still not sure
I believe Dodge uses that "hat" of an intake tube is to keep the flow of air quiet. It's a resonator of sorts. A muffler for your intake. I too see that outside air is getting into the airbox by way of that snorkel tube from the passenger fender. So, keeping with that, I added a K&N drop in filter and added an Airaid Modular Intake Tube (MIT), to replace the stock hat. Between that upgrade and the Flo 40 SO/DO exhaust, my truck has much better throttle response. Feels much quicker off the line. The exhaust really sounds like the engine is breathing well to. I think it's a great happy-medium to a full FIPK/CAI kit. And saved some $ from the full kit (which still gets it air from the engine compartment, I believe).
[IMG]local://upfiles/41180/011984CBD2EB47BC953F5732166E5712.jpg[/IMG]
Old Sep 18, 2006 | 06:24 PM
Mantis's Avatar
Mantis
Looks Nice![sm=bounceybounce.gif]
Old Sep 18, 2006 | 07:37 PM
Beazer's Avatar
Beazer
I've actually considered buying some conduit or PVC from one of the home inprovement places and running it from the opening in the fender to my right foglight space. Since I don't have foglights, and don't want them, I thought about cutting out the openings between the slats and and hooking the tube up as somewhat of a "RamAir" intake by having the air forced into the airbox when the truck is moving. This would definately send cooler air into the filter, or onto a CAI, and possibly increasing HP opportunity. The only drawback I've found is the space up at the fender opening seems narrower than the rest of the area.
Old Sep 18, 2006 | 07:46 PM
ETXDak's Avatar
ETXDak
I'm running a K&N drop in with a Airaid modular intake tube and using the factory exhaust with the muffler removed, resonators only,pretty happy with it,tried the K&N CAI # 63-1546 didn't like the way it ran,may try it again with some other mods.
Old Sep 18, 2006 | 09:41 PM
igneous's Avatar
igneous
I almost guarantee you won't feel or see any difference with a CAI. Totally not worth it.
Old Sep 18, 2006 | 11:01 PM
superdak05's Avatar
superdak05
i totaly got rid of the whole intake system and went with the k/n fipk. the hat over the tb on the dodge system is only for advertisement for the engine size. also with the k/n system you can relocate your iat sensor eaiser.
Old Sep 19, 2006 | 07:31 AM
lil's Avatar
lil
advertisement? Where do you come up with this stuff??.....It is called a Silencer for a reason....and a full CAI kit weather is be K&N or Airaid or another good brand does make a difference in flow volume putting in more air/fuel mixture and if you set it up right cooler air making this mix denser I mean it is simple physics very strait forward even I understand it.
