Customized CAI
Old Jan 25, 2007 | 07:44 PM
DakotaStone's Avatar
DakotaStone
Default Customized CAI
I went to a speed shop today. I wanted to find out if they have pipe bending machines, and sure enough, they do. So, I have three choices for creating a new CAI. One would be to buy the twin, have both sides bend around and away from the manifolds to get the cold air.
The second choice would be to take and make a single tube and branch it into a two tubes with two filters.
The third choice would be to do it like they do to the Ricers, and put it through the side of the truck through the wheel well. I'll be using alum tubes for the colder air, which of course is way better.
The problem with the first choice is, not a whole lot of room to work with. I would have to relocate the battery somewhere else on the truck
The problem with the second choice is it would be about $400. I'd get a higher volume air going in.
The problem with the third choice is they would probably have to have the hole relocated else where instead of the factory whole and I would probably have to clean the filter more, even though that's only what, $10? But, I would have a continous amount of cold air coming in.
What do you guys think?
Old Jan 25, 2007 | 07:48 PM
shnormo's Avatar
shnormo
Default RE: Customized CAI
Remeber when you pick up volume, you lose velocity which means less torque. Which is a better insulator? Plastic or metal. Plastic is a better insulator.
Old Jan 25, 2007 | 07:50 PM
Chris's Avatar
Chris
It isn't a CAI until it is receiving air from outside of the engine compartment just to let you know.
Old Jan 25, 2007 | 07:54 PM
DakotaStone
ORIGINAL: shnormo
But, Aluminum is a better conductor for cold air.
Viused, that's why I'm leaning more and more toward my third choice.
Old Jan 25, 2007 | 07:55 PM
RMUDBUGS's Avatar
RMUDBUGS
Very small air tempature differance for metal and plastic. The air moves through it so fast it doesn't have time to heat up. More importantly is were you get the air from, the colder the better, so the 3rd choice would be the best.
Old Jan 25, 2007 | 09:55 PM
ETXDak's Avatar
ETXDak
I seen on another forum some guy wasselling a ram air kit for the full size Dodge,the scoop waslocated on the side of the radiator about where our coolant/windshield wiper fluidtanks areat,seems likesomething simularmight work on the Dakota,you would have to figure out where to relocate the tank though,not alot of room in that engine bay.
Old Jan 25, 2007 | 10:03 PM
DakotaStone
The only problem with that is, you'd have to relocate the coolant resevoir and the window cleaner bottle. Not sure exactly where I'd put something like that.
Old Jan 26, 2007 | 01:09 AM
ETXDak's Avatar
ETXDak
This is what I was talking about.didn't see any pics of the complete system just the scoop on the side of the radiator,guess he doesn't want to give away his ideal.
http://www.airram.com/products.htm
Old Jan 26, 2007 | 01:25 AM
superdak05's Avatar
superdak05
save your money, go to the hardware store and get yourself a funnel, cut the end off of it and connect a tube to that , that will deliver cooler air to the system.
Old Jan 26, 2007 | 02:11 AM
DakotaStone
Go to http://store.racinglab.com/weramairkit.html. I'm actually interested in this, if nothing else, for the looks.
