Fiberglass quad cab sub enclosures?
Old Feb 9, 2007 | 01:08 AM
bkjtimp's Avatar
bkjtimp
Default RE: Fiberglass quad cab sub enclosures?
it wouldn't go over the hing though
Would the ones you make be notched to fit over the hinge? Another issue I have is that the Sirius componant is there between the seat hinges, so the box would have to fit over that too (It almost looks like a small amp).
Old Feb 10, 2007 | 07:12 AM
snobrdrdan's Avatar
snobrdrdan
What side of the seat are you thinking about???
And if you made it compatible so that the seat could still flip up....people would be all over these!!!
The MTX box fits all Quad Cabs....so you could market these to the Gen II guys too!
Old Feb 11, 2007 | 12:45 AM
bkjtimp's Avatar
bkjtimp
There is a seat mod I read about on another site. You remove the rear seat back portionfrom the veh, grind down the two tabs on the back of that seatback--the tabsthat fit into the slots on the back wall of the truck. If it's ground down to thet first weld/indentation area (per this other guy), once it's put all back together, the tab is long enough to engage the part on the back of the track when the bottom seat is down, but as soon as you lift up the lower seat alittle, the upper part disengages with the back wall and now the seat back will fold down on top of the bottom---and still open the seat bottom to access tools, etc.
Old Feb 11, 2007 | 06:33 AM
snobrdrdan's Avatar
snobrdrdan
Hmm...I sort of understand that trick, but the seat won't go up all the way because the bottom cushion slams into the sub box......well that's how I dented my JL sub grille when I was hooking up my amp......I didn't have the uprightcushion on and was making the connections under the lower cushion and had it only so high because the bottom cushion was smashed into the grille for the sub
Old Feb 11, 2007 | 02:48 PM
DynoDan's Avatar
DynoDan
If your looking for a sub that will fit check out the kenwood preamped sub i think it will fit underneath the rear seat. They work with one active sub and one passive radeater speaker .
