throttle body update
Old Mar 6, 2007 | 02:04 AM
  #21
DakotaStone's Avatar
DakotaStone
Default RE: throttle body update
Let's just say that it's a bit more perky. I talked to Dan and he does ECU flashing. He charges $400 for it. I'll probably do that after a couple of years. Man, this truck will be stout as ever. Too bad it takes all of these mods to do it though.
Old Mar 6, 2007 | 02:15 AM
  #23
DakotaStone
Between Dan and KRC Performance, cams are about $750. The flash is the same thing as using the Superchips module. He also told me that polishes and ports the heads on it. He didn't give me a price, so I can't tell you.
Old Mar 7, 2007 | 12:19 AM
  #25
importandy's Avatar
importandy
A bore would be a huge waste of money, I built motors for a few years and honestly, for the amount of work to tear the engine down, pay for the pistons and rings, bore and reassemble for maybe 5 or 6 HP...total waste. We only recomend a bore if the engine is tired, coming apart already and the holes are out of spec. Now, a bore and a stroker kit would be nasty, but just a bore...waste.
Old Mar 7, 2007 | 02:10 AM
  #26
DakotaStone
Unless I was serious about drag racing my truck, i wouldn't bother with the stroker kit. Way too much money. I agree though, it'd be worth it in the end. Probably could find a good strocker engine in the junk yards.
Old Mar 7, 2007 | 09:17 PM
  #27
Dusty's Avatar
Dusty
What do those numbers say?
Old Mar 8, 2007 | 12:11 AM
  #28
importandy's Avatar
importandy
I am excited to see what my truck does with the stage 2, electric fan, tb, lower t-stat and maybe a cam.
Old Mar 8, 2007 | 01:02 AM
  #29
Dusty's Avatar
Dusty
Your truck would probably like two cams better.
Old Mar 11, 2007 | 12:06 AM
  #30
importandy's Avatar
importandy
Dusty, where did you get your phone and how much was it??>>
