Head Rest In The Rear Window's and Tires
Old Mar 20, 2007 | 12:22 AM
Frenchy's Avatar
Frenchy
Default RE: Head Rest In The Rear Window's and Tires
Get em from the dealer... or Napa... or somewhere, they aren't expensive..
Old Mar 20, 2007 | 12:52 PM
Flyhalf's Avatar
Flyhalf
You're correct...I didn't see where he said sliding. Either way, the head rests are easy to remove if you need to.
Old Mar 20, 2007 | 02:16 PM
Chad05's Avatar
Chad05
They have the verysame clip's that connect the back wall?
Old Mar 20, 2007 | 03:26 PM
Flyhalf's Avatar
Flyhalf
Yep...I always go to Pep Boys and just buy the assortment package. You can get clips, plastic fasteners, etc. It's good to have an assortment. Should cost around $5.
Old Mar 21, 2007 | 02:27 PM
Chad05's Avatar
Chad05
Hey when you and ur friend put that back wall back in did you have too remove the side panel's that cover the speaker's and where the seat belt retractor is, it seem's to me they have to come out to get that wall back in dunno, i will attempt it again tonight so lol.
Old Mar 21, 2007 | 02:37 PM
Flyhalf's Avatar
Flyhalf
It's easier, but not necessary. Also, you do not need to remove the back wall. Just pull outward at the top untill you can see the bolts. You will need to pull about 2 or 3 (can't remember) of the plastic clips out of place, but do not remove the entire wall.
