Head Rest In The Rear Window's and Tires
I have a 2005 ClubCab and i have those head rest's in the rear window's i think it has been talked about here before, i am wondering how to take those out cause it will be easier to tint those sliding rear window's without them there, and i have another deal i recently discovered a nail in my driver rear and well i changed that tire with my spare luckly it was'nta stupid donut lol and when i took it in to swap tires this kid noticed another nail in my passenger rear, i was kinda mad but i have been paying attention and i know that i needed to change my rear's soon, this nail must have been in there for a while cause it's wore down haha, i have priced my size and well, wow expensive, i am wondering if any of youhave a couple of tires or if anything i will just buy one for now, i have the GoodYear Eagle's LS 255/65 R16, so if anyone can help a brotha out, i would appreciatethe help.
Guest
Posts: n/a
Is your truck a base modle? I have goodyears but not the Eagles... I also cut a rear tire... I went to my dealer and bought one that was a lease take off for 85 bucks... it mathced my tread wear pretty well too. I would maybe try that too, you might get lucky.
As for tinting with the head rests... your back window is a 3 piece , so its pretty easy to do. even with the head rests in there. the 3 parts of film should be small enough to work with . just make sure your window is really wet. that way you have time to set them just right...
Trending Topics
His rear window is probably a 1 piece like mine. Absolutely have to take the head rests down. Like someone else said. Pull the top of the plastic wall outward and remove the bolts holding the headrests in. They will slide out of the top. Don't need to remove the entire back piece of plastic. Just pull far enough back to seethe bolts.
Well, I'll write a little about the tires. I too have the Eagle LS 255/65/16...I really hate them-Crappy in the snow and not really good in the rain either. Just not my cup o' tea. And, to top it off, they are a "wierd" size and not a ton of same-size other tires avail. General Grabber AT2 is one, Goodyear Fortura is another, and of course you can get another Eagle LS. I think I will change to the 275/75/16's instead..They are about the largest that will fit w/o a lift. And there is much greater choices in that size. I will have to go to the dealer to get the computer re-coded with the new size so the speedo is right. I just can't wait to get rid of these Eagles....
