My Trailmaster 2" kit problems fixed!!!
Old 03-24-2007, 12:56 AM
LB's Avatar
LB
LB is offline
Default My Trailmaster 2" kit problems fixed!!!
Hi All,
Just an FYI update on my expercience with a Trailmaster 2" leveling kit that preloads the springs. (See previous post on problems I had) I purchased 2 new struts from Dodge along with the 2 washers that go on the strut before it gets bolted to the top plate. I had these installed and made sure the Tech was competent, and all of my noise problems went away, it is as tight as it was before the first install, the ride height is perfect and I love it.
Those of you with the preload setup and have noise and clunking issues, grab the top of the front tire and tug on it outward trying to rock it. This loads the suspension, while doing this look at the top of the shock strut, if it moves up and down seperate from the mount, it is loose and needs to be tightened. My installer actually dropped the shock and the washer that goes on the shaft fell off (see page 5 (I think) on TM install directions)causing one of mine to be REALLY loose.
Sorry for the long post, but maybe this can help others with problems.
Now I just need to get tires for my 07 chrome RAM 20" wheels!!!
Thanks,
LB
Old 03-24-2007, 10:34 AM
moosehunter's Avatar
moosehunter
moosehunter is offline
Default RE: My Trailmaster 2" kit problems fixed!!!
Will have mine install soon too, glad your noise problem is fixed and that the TM level kit wasn't the problem but[sm=ttiwwp.gif]
Old 03-24-2007, 01:38 PM
Mopar420's Avatar
Mopar420
Mopar420 is offline
Sounds good man..
Old 03-24-2007, 02:01 PM
Mopar420's Avatar
Mopar420
Mopar420 is offline
It sucks these trucks are 5 lug as where the 2ND GEn are 6
Old 03-24-2007, 02:06 PM
LB's Avatar
LB
LB is offline
How do I upload pic's?
Old 03-24-2007, 02:09 PM
Mopar420's Avatar
Mopar420
Mopar420 is offline
Save it in paint as a JPG and dont go to fast reply actually click reply..Then click UPLOAD PIC..Go browse and then find it on ur comp..Click upload and it should upload no problem
Old 03-24-2007, 03:24 PM
LB's Avatar
LB
LB is offline
Here are some pics before and after (not great with shadows, but I will get more!).
Also a pic of my 07 chrome ram 20's. I am still deciding on 265/50/20 (almost exact diminsions of the original 16", or 285/50/20 which are about 3/4" taller and 3/4" wider. I also think the silver painted 20" ram whels would look better with the silver color, but my friend thinks the chrome matches the Lamarie chrome. I would trade for silver if the oppertunity arises. Also trying to sell the 275/60 tires, they have 8 miles on them.
LB
[IMG]local://upfiles/30378/97BD6898D54E46D39D0BEF3A9AFA671D.jpg[/IMG]
[IMG]local://upfiles/30378/DB6E0767C213429181DA89356E893853.jpg[/IMG]
[IMG]local://upfiles/30378/E46BC8B2BE1D4C71AB1B85FA8544D71A.jpg[/IMG]
Old 03-24-2007, 03:40 PM
moosehunter
Great pictures and sharp looking, can't wait to have my level kit install. I like the look of it.
Old 03-25-2007, 12:48 AM
texanrcp's Avatar
texanrcp
texanrcp is offline
looking good
Quick Reply: My Trailmaster 2" kit problems fixed!!!
