3rd Gen Durango 2011+ models
battery?
Old Sep 16, 2011 | 10:43 PM
baum's Avatar
baum
Default battery?
can anybody tell me where the car battery is located and how to get to it??
Thanks
Old Sep 16, 2011 | 11:37 PM
IndyDurango's Avatar
IndyDurango
Page 464 of the owners manual, "The battery in your vehicle is located under the passen-
ger’s front seat"
Old Sep 16, 2011 | 11:38 PM
fincher's Avatar
fincher
Underneath passenger seat.
Old Sep 17, 2011 | 12:13 AM
sidewinder9m's Avatar
sidewinder9m
Under the passenger front seat. Check out this youtube vid....
http://youtu.be/7PjYgeOsP3I?hd=1
Old Sep 17, 2011 | 12:17 AM
darkmanrob85's Avatar
darkmanrob85
if you open the hood, on the left side you'll see where to put the jumper cables just in-case you need a jump
Old Sep 17, 2011 | 12:54 AM
baum's Avatar
baum
Thanks!!
I am adding an Amp and subs. i knew the jumpstart plugs where under the hood.
I must not hae received the same owners manual unles its online somewhere. mine was like a 200 page folor book and then a dvd.
Old Sep 17, 2011 | 01:32 AM
IndyDurango
Yes, it is available for free download online.
IndyD
Old Sep 17, 2011 | 02:18 AM
Robert_Esq's Avatar
Robert_Esq
Originally Posted by baum
Thanks!!
Dude, what AMP are you adding? Where are you putting it? In the floor storage behind the 3rd row?
I got the DVD and tiny book as well. I tried to look one morning to connect an DC-AC converter and was stumped.
Old Sep 17, 2011 | 10:26 AM
NY-Durango's Avatar
NY-Durango
To access the battery move passenger seat all the way forward and open hatch from behind front seat. You will see a little lip give it a good tug and it will pop open.
Old Sep 17, 2011 | 05:13 PM
baum's Avatar
baum
I hace had a crossfire amp and jl subs and diamond audio components.
I replaced the the factory components. i put the amp in the storage bin next to the factory sub. i dont have a 3rd row seat so i have 2 large storage bins there i built a custom box to fit there for 2 12's. I used a scosche hi-lo converter to grab signal. i grabbed my signal comming out of the factory amp for the fronts. the factory amp is located under the storage bin below the flash light. I grabbed my remote turn on from the power leading into the flash light. i only used it to trigger a relay i didnt want any current draw on it.
I was actually surprised how well the factory sub sounded without that thick plastic cover above it.
