3rd Gen Durango 2011+ models
No Charge Maintenance Service Intervals?
Old Feb 8, 2012 | 12:57 PM
fuzzyb's Avatar
fuzzyb
Today I was looking for the services with the No Charge Maintenance. Couldn't find it so I pulled up my contract on line and did a copy/paste to here.
Your vehicle is covered by:
•3/36 NO-COST MAINTENANCE PLUS
(Option Code: DMC336 Form Num: DMC336)
Service Interval
Maintenance Service - Date of Service / Mileage / Dealer Initials
•3,000 Miles Oil change/filter
Front Suspension Lube
Form Num: DMC336 Page: 4 of 6
•6,000 Miles Oil change/filter
Tire rotation
Lubricate front drive shaft fitting (2500 or 3500 4x4 models only)
Top off engine fluids
•9,000 Miles Oil change/filter
•12,000 Miles Oil change/filter
Tire rotation
Replace air conditioning filter
Inspect the brake linings
Inspect the CV joints
Inspect the exhaust system
Inspect the front suspension, tie rod ends and boot seals for cracks or
leaks and all parts for damage, wear,
improper looseness or end play
•15,000 Miles Oil change/filter
•18,000 Miles Oil change/filter
Tire rotation
Inspect the front and rear axle fluid, change if using vehicle for fleet,
off-road or frequent trailer towing
•21,000 Miles Oil change/filter
•24,000 Miles Oil change/filter
Tire rotation
Inspect brake linings
Inspect CV joints
Inspect exhaust system
•27,000 Miles Oil change/filter
Form Num: DMC336 Page: 5 of 6
•30,000 Miles Oil change/filter
Tire rotation
Inspect transfer case fluid level
Replace plugs (3.5L and 5.7L engines only).
•33,000 Miles Oil change/filter
•36,000 Miles Oil change/filter
Tire rotation
Inspect the front and rear axle fluid, change if using your vehicle for fleet,
Old Feb 8, 2012 | 06:29 PM
kingskib's Avatar
kingskib
i passed this info onto my dealer (in Canada) and told me this is a USA thing only :'(
Old Aug 15, 2012 | 09:04 AM
fuzzyb's Avatar
fuzzyb
So the Durango was in for its 12K service, they didn't change the AC filter (like they should have). I removed it that evening and it was / is dirty.
They also said it will need an (engine) air filter next time. Shouldn't this be covered under the No Charge Maintenance? I didn't see it outlined or excluded in the contract.
Old Aug 15, 2012 | 09:18 AM
moparmommy's Avatar
moparmommy
I brought mine in at 3400 miles or so, and the sticker they put on the car says to come back at 8200! But I have that no cost maintenance plan, so I think I will just be following that schedule..
Old Aug 15, 2012 | 12:25 PM
Scalpel's Avatar
Scalpel
Originally Posted by fincher
Good. I plan on doing a 3k one for sure. We've got 1900 miles so far. Going to go to our local Dodge dealer not the dealer from where we purchased -- just too far.
So any truth to you get treated better as far as deals or service if you go to your purchased dealership instead of the nearest one....I am in same boat and is wondering if that is just a load of bull.
