3rd Gen Durango 2011+ models
Alignment issue
Old Mar 23, 2012 | 02:17 AM
2012DurangoSXT's Avatar
2012DurangoSXT
Default Alignment issue
Hello all....new owner here of 2012 SXT AWD.
I am having an issue with the alignment on the vehicle. I can feel the vehicle pulling to the left on the highway at 75-80 mph. Needless, to say it was getting annoying on a 4 hour drive. The muscle in my arm were getting strained due to correcting the steering constantly. The interstate was flat and straight with no visible imperfections. I don't notice the steering issue in local driving etc.
Anyone having a similar issue? Also, any new technical service bulletins on this?
I currently have 3k miles on the vehicle. It was brand new when I purchased it. I will have the dealer look at it when I change the oil.
Ryan
Old Mar 23, 2012 | 04:59 AM
CFUSION's Avatar
CFUSION
I just went through hell getting my brand new Durango's allignment fixed. Spent all day at the dealer twice. Test drove it 4 times. Kept telling them a little more to the left. Finally thought it was perfect. Drove home and still not right. Giving up.
Old Mar 23, 2012 | 09:15 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
are you certain the interstate was 100% truely flat? i only ask because every single interstate in my area has crown to it enough to cause the truck to pull, some are crowned towards the center, some towards the shoulder, and some curve so you pull right in the right lane and left in the left lane. this is done for drainage but can get annoying when driving on them for extended periods of time.
Old Mar 23, 2012 | 01:18 PM
HunterSwift's Avatar
HunterSwift
My r/t has pulled to the right since day 1
Old Mar 23, 2012 | 01:55 PM
sidewinder9m's Avatar
sidewinder9m
Fortunately my Citadel pulls straight from Day 1! also tires have been rotated once already.
Old Mar 23, 2012 | 03:01 PM
DodgeCares's Avatar
DodgeCares
Ryan
Ryan,
There are no TSB's regarding alignment. Have the dealer look at it and take care of it for you next time you are in there.
Old Mar 23, 2012 | 04:54 PM
dirtydirtyJustin's Avatar
dirtydirtyJustin
i would say the R/T pull more one caues the how wide the tires are. mines to the right too has been looked at once they said they fixed it but still pulls
Old Mar 23, 2012 | 06:21 PM
PowerDDanger's Avatar
PowerDDanger
All of the Durangos use the same width tires....
Old Mar 23, 2012 | 07:24 PM
JRRF's Avatar
JRRF
Chances are good that your vehicle will pull a little to the left while in the left lane of an interstate, and a little to the right when in the right lane, because of the slight crown in the road. If however you are in the left lane and the car pulls right enough to go over the crown, or vice versa, then you have a problem that needs to be corrected. If a good four wheel alignment doesn't fix it, then it could be a bad radial tire. That's something the dealer may not be able to check, but a reputable tire shop should be able to.
Old Mar 25, 2012 | 12:34 AM
2012DurangoSXT
Thanks everyone for the help! Yes, I have had the problem on many different types of roads. It is more pronounced at higher highway speeds. I will take into to dealer first to get a 4 wheel alignment and tire rotation. I will keep all you posted.
