Custom OEM Mopar Steering Wheel Discount
#52
#57
#58
#60
removal & installation
19 - Steering/Column/WHEEL, Steering/Removal
REMOVAL
Labor Operations: Click to display a list of Labor Operations associated with this procedure
WARNING:Before servicing the steering column the airbag system must be disarmed. Failure to do so may result in accidental deployment of the airbag and possible personal injury..
INSTALLATION
REMOVAL
- Position front wheels straight ahead.
- Disconnect and isolate the negative (ground) cable from the battery.
- Disable and remove the drivers side airbag (Refer to 10 - Restraints/AIR BAG, Driver - Removal) .
- Disconnect all electrical connectors.
- Remove the steering wheel bolt (1).
- Remove steering wheel damper, if equipped.
- Slide the steering wheel (2) off the steering column assembly.
INSTALLATION
- Install steering wheel (2) onto the column.
NOTE:Do not reuse the old steering wheel bolt (1) (a new bolt must be used)
NOTE:Be certain that the steering wheel mounting bolt is tightened to the proper torque specification to ensure proper clockspring operation.
- Install steering wheel damper, if equipped.
- Install the new steering wheel bolt (1). Tighten the bolt to 80 N·m (59 ft. lbs.).
- Reconnect all electrical connectors.
- Install the drivers side air bag (Refer to 10 - Restraints/AIR BAG, Driver - Installation) .
- Reconnect the negative (ground) cable to the battery.
