3rd Gen Durango 2011+ models
Any experience getting an extra FOBIK keyless fob programmed
Old Aug 17, 2012 | 12:44 PM
cpcordell's Avatar
cpcordell
Then I guess it depends upon the dealer as to how much they will charge for the programming.
I might grab the $79 one on Ebay and ask around for the programming charges.
I would like to have a spare FOBIK in the car (hidden) without the batteries installed for backup/emergency (keep batteries next to it though). If I can hide a spare metal key for the door somewhere around the vehicle, once I get in I can power up the FOBIK and drive.
I have a friend who hides a spare door key inside the turn signal bezel -- just need to have a screwdriver to get it but it is totally hidden even if you know where to look.
Old Aug 24, 2012 | 11:59 PM
CMil527's Avatar
CMil527
Any updates on this I need another fobik as well!
Old Aug 25, 2012 | 07:21 AM
bbtkd's Avatar
bbtkd
If you have two functioning FOBIKs you cannot add a third for the keyless-go, only as a remote.
If you have only one functioning FOBIK, the dealer can program another virgin one for you, but you'll have to replace the existing one with another virgin one also. So if you lose one and need two, it will cost you about $400 at dealer prices for two new FOBIKs programmed to your car. You may save some money - if your dealer is cooperative - by buying the re-virginized (!) ones on Ebay. Either way, you will end up with a non-usable one that you could send off to be re-virginized, and you could then resell it on Ebay.
Unless you test it, don't be so sure taking the batteries out will defeat the FOBIK proximity function. Since proximity range is only a few feet, I suspect it is RFID and therefore does not require a battery - that is probably only for the remote button functions.
Old Aug 25, 2012 | 10:12 AM
CMil527's Avatar
CMil527
Thanx man... I lost one last night so I only have one now!
Old Aug 25, 2012 | 10:27 AM
bbtkd's Avatar
bbtkd
That sux. If there is a chance of finding it, that could save you $400.
Old Aug 25, 2012 | 01:45 PM
safford197's Avatar
safford197
Did you get the pin from the dealer for the system? I read the manual a couple days after delivery and found a statement about a pin. If you loose both keys then there is a module in the vehicle that would have to be replaced if you don't have the pin. So I asked my sales person and she had never heard of it so she took me to the parts department and the guy looked it up by VIN. He said if you don't have the pin and don't have the keys they will charge you to look it up... I guess it's up to different stealerships what they are going to charge.
If you're worried about the battery in the FOB don't. You can use the spare key built into the FOB to open the door and remove the cover on the push start. That will reveal a slot to insert the key. Once inserted it can read the ID if the battery is good or not. If you're worried about locking the key inside there are supposed to be sensors but I'm sure there are weak spots in their coverage so there could be a possibility of locking the key in. Why not simply copy the hard emergency key and put it in a magnetic key holder under the vehicle somewhere like we used to do in the good old days?
Bottom line is plan ahead and your cost is minimal - wait for the emergency and you'll pay for it!
What ever the intent, security I presume, the net result is honest people are flipping the cost of this. I think it's total BS - just my $.02
Old Aug 25, 2012 | 01:57 PM
bbtkd's Avatar
bbtkd
The pin is on a sticker that was on the bag the FOBIKs come in. The government is levying requirements on manufacturers and dealers to make changes like this. By making it difficult or impossible to program your own remotes, Keys, and FOBIKs, they make life more difficult for the more casual thieves who might otherwise make a new FOBIK while at the car wash or repair shop - then steal it later.
Old Sep 4, 2012 | 05:31 PM
sagemajor's Avatar
sagemajor
I just had 2 additional keys programmed to my D, for a total of 3. I had it done at a Local locksmith, the key cost me 150 each. All 3 work for the proximity entry and push button start.
They charge $60 to program and cut a key if I brought it in.
Old Sep 4, 2012 | 10:27 PM
CMil527's Avatar
CMil527
No luck yet but hersheypark has my number... it flew out of my pocket on skyrush!!
Old Jan 23, 2013 | 09:49 PM
domdoma's Avatar
domdoma
I got a blank Fob/key online for $65.00 and then had the dealership program it for $55.00.
So now I got three (3) Fob remotes...one for me, one for my wife, and an extra one at the house
