3rd Gen Durango 2011+ models
Is Smart Beam auto high beams a standard feature?
Old Jul 24, 2012 | 03:06 AM
Didhefocus's Avatar
Didhefocus
Cadillac had this feature in the early seventies according to a freind of mine.
I've tried it and it worked perfectly for me! The sensor it uses is actually a camera in the rear view mirror base!
Old Jul 24, 2012 | 09:57 AM
coldsteel's Avatar
coldsteel
Yup. the only issue that I have encountered is it cannot distinguish between oncoming headlights or strong reflections from road signs.
Here in the Northern VA area, they are really good about replacing worn signage so they are all practically new and ridiculously reflective which causes the lights to dim until you pass the sign. it is still MILES better than pushing/pulling the hi beams on and off every 30 seconds for oncoming cars
Old Jul 24, 2012 | 02:39 PM
HeMiDD305's Avatar
HeMiDD305
"SmartBeam™ intelligent headlamps automatically adjust high-beam brightness and intensity to ambient light when there’s oncoming traffic"-Dodge
I've owned my 11 Crew Hemi for just over a year, and as far as I know, everyone has the smart beam feature on their D. You have to have the high beam initiated for it to begin adjusting from hi to low. Once on a dark road, hit your high beam and as you approach lights, the beam will adjust to low
Old Jul 24, 2012 | 04:09 PM
moparmommy's Avatar
moparmommy
I keep my lights on auto, so it comes on with the headlights, but my husband always turns it off since it bugs him by hitting the hi beam lever.
Old Jul 25, 2012 | 09:36 AM
JRRF's Avatar
JRRF
The biggest issue I have is that if you are driving somewhere at night and all of a sudden really need your high beams, you turn them on, and then.........there is some reflection, or a red tail light in the distance, they DON'T come on. It's very frustrating to lose that sense of control over something I really need right when I need it.
Old Jul 25, 2012 | 09:53 AM
SadaraS's Avatar
SadaraS
I was looking at my new Durango's window sticker online and I don't see the Auto High Beams feature. I did notice it was added to the Crew on the showroom floor at the Dealership yesterday. I don't mind not having it. I'm ok with the headlights coming on automatically, but the high beam being automatic would probably end up bothering me.
Old Jul 25, 2012 | 11:08 AM
coldsteel's Avatar
coldsteel
Since the Smart beam requires the stalk to be in the hi-beam (forward) position, if you need the hi-beams immediately, you can either A)pull the stalk to middle and then back into the flash-to-pass position or B)spin your headlight switch from Auto to ON and your hi-beams will switch to normal function, which will illuminate them immediately since the stalk is still in the forward position.
