730N copying large number of MP3's from USB to HD
Hi,
I have questions regarding copying a large number of MP3's from USB to HD.
I have approx. 18GB of music on the USB.
1.
How should the directory structure of the USB be organized? Is it possible just to copy Music folder from iTunes onto the USB and then copy it onto the HD, or does the 730N require to have all MP3's in the same root level directory?
2.
Manual says that the speed of transfer is 2MB/sec, hence 120 MB per minute hence 7.2GB per hour. So the transfer from my USB will take up to 3 hours. How am I supposed to keep the 730N system alive for such a long time? Would not it shut down automatically after some time? If yes, is it possible to resume the transfer later on or would the subsequent attempt to transfer the MP's start from the beginning, thus creating a never ending process?
3.
Where should I put my playlists? Can they be in a separate directory on the USB, or should they be put in the same directory as MP3's?
Thanks for any advice or pointer
Cheers
Frank
1.
2.
3.
Cheers
Frank
1. The mp3s need to be on the root of the USB drive. When they are copied, you will have a folder on the HDD that has a label for the USB drive, i.e. USB Drive 1, the second copy you do will create a 2nd folder.
2. The car has to be running for the files to copy over. If it's going to take 3 hours to copy, then you need to have the vehicle running for 3 hours. Fun!
3. Can't answer this, I've been creating my playlists on the radio, not on the USB drive. I suspect it won't accept playlists from the USB drive. I can't confirm this though.... someone else may have better information.
You don't have to have the vehicle running, just in ACC mode. Hit the button one time without your foot on the break to get to ACC, twice for run.
Then hook up a trickle charger to your battery. That will replace the lost current from the radio being on. However, a tricle charger isn't enough to run an amp, so turn the music off(with the volume button) so you don't kill your battery. That will work for at least 15min,(thats the longest I have sat in that mode) but should stay that way for the 3 hours, unless dodge put some trip to shut it off after so many minutes.(doubtfully)
Or You can get a portable hard drive or USB stick, large enough for your music. Format it in FAT32 and then develop the folder structure on the computer Because the 430 RHB reads it like windows folder structure. Not sure on the 730N. Also a tid bit of information is that if you have all the info filled out in itunes or WMP it should keep in the gracenote section and when you plug it in you have all the artist info, song, track, album.....etc..... that way it is removable and time, gas isnt wasted and your not relying on a car HDD to keep all your music.
I havent tried an ipod in mine to know for sure but it has some lag but not enough to even care about. Also it seems to have alot better sound quality then playing through an ipod or my android phone in my case. I think the lag in change of track is due to a lack of processor speed and read/write times... good luck it works great.
Trending Topics
I just have one last question:
If the transfer from a USB stick to the HD is interrupted and a new transfer is initiated from the same USB stick later on, will it transfer the files that are on the HD already, or just the files that has not been transferred yet?
Thanks
Frank
