3rd Gen Durango 2011+ models
Headlights fuse(s)
Old Aug 14, 2012 | 10:16 PM
Scottina11heat's Avatar
Scottina11heat
flickering halogen? HMmmmmm....def, sounds like a bad ground somewhere, wire thats been damaged somehow or maybe the fcm going bad. Either way the dealer should be involved.
Old Aug 14, 2012 | 10:35 PM
bbtkd's Avatar
bbtkd
Originally Posted by Cruiser478
Thank you Scottina,
What is the front module?
The reason I'm asking is that my friend's 2012 Crew Lux AWD HEMI's low beam headlights flicker irregularly while the engine is running. When the engine is off there is no flickering. He took it to the dealer, who tested the alternator and the battery and said everything was Normal.
Any thoughts would be really appreciated.
What a shocker! A dealer can't figure it out, so everything is fine! Seems to be a common theme on the forum. Too many mechanics don't understand the internals and have no problem solving skills or logic, so if their tester can't detect a problem then it is normal.
