3rd Gen Durango 2011+ models
**HOW TO** ADD 2012 Jeep SRT8 Brembos to your 2011+ Durango
Old Aug 30, 2012 | 01:19 PM
Scottina11heat's Avatar
Scottina11heat
Default **HOW TO** ADD 2012 Jeep SRT8 Brembos to your 2011+ Durango
....gone
Old Aug 30, 2012 | 01:28 PM
CFUSION's Avatar
CFUSION
You the man! Thanks for the great info.
Old Aug 30, 2012 | 02:08 PM
budoboy1's Avatar
budoboy1
You're a good man. Great info!!
Old Aug 30, 2012 | 03:07 PM
CMil527's Avatar
CMil527
Great info bro... Nice job!
Old Aug 30, 2012 | 03:29 PM
jwr9152's Avatar
jwr9152
Awesome. Thanks for the info
Old Aug 30, 2012 | 10:25 PM
Scottina11heat
no problem
Old Aug 30, 2012 | 11:12 PM
IndyDurango's Avatar
IndyDurango
Originally Posted by Scottina11heat
results speak for themselves.
Uhhhhhh. ???
Stock runs 60-0
stock 2 piston front(vented)/single piston rear(solid disc)-STOCK pads
toyo proxes st2 tires
76 degress sunny-0 wind 11:30 am
using utility pole as brake slam point
1st stop from 60
14 ft.
2nd stop from 60
17 ft
3rd stop
24 ft
4th stop
32 ft
6 piston front Brembos
6 piston Brembos on front w/raybestos pads and stock 15" rotors
1 piston rear w/solid disc, stock pads
84 degrees, cross wind 230 pm...same circumstances as above
1st stop
7 ft
2nd stop
1 ft
3rd stop
-2 ft
4th stop
-2 ft
Okay, I'm lost. Are your second results THE DIFFERENCE from the first results? If so, it should be recorded as such.
As it reads (to me... and it is late) you stopped from 60MPH in 7 feet (face against the windshield no doubt) and then on the 2nd stop in 1 foot (likely you died from the impact) and then somehow slide backwards by 2 minus feet after the 3rd and 4th stops. Perhaps there is a time machine switch in those SRT brembos that places you back two feet from the previous stopping point as you engage them after 2 consecutive stops in the same place? Dunno. Maybe in the afterlife from the death of stop #2 we go backwards instead of forwards.
Perhaps the 4 guys that patted you on the back after the post are some sort of super scientists that can figure all that out. As for me... just a simple midwestener.
You can interpret the results as you please.
I did.
IndyD
Old Aug 30, 2012 | 11:19 PM
CMil527's Avatar
CMil527
A veryyyy simple midwesterner...lol!! i've read Scott's results over on jeepgarage prior to this post so I was simply reitterating my appreciation for his efforts it's too late for me to try to interpret the results again!!
Old Aug 31, 2012 | 09:42 AM
Scottina11heat
Reading comprehension Indy....LOL
Quote "Using one utility pole as brake slam point(emergency braking maneuver)
next utility pole as measuring point(just worked out that way) Plus I had no measuring device longer than 25 ft to measure distance between utility poles. Test conducted on private site/company owned/closed."
It is a little hard to read I guess if you skim through real quick. But I used one utility pole as the braking point and the next utility pole as my measuring point because I didnt have a measuring device long enough to measure between the poles. I would guess its about 100 ft. between the poles. So you can add say 100 ft. to each of those measurements.
Old Aug 31, 2012 | 09:45 AM
Scottina11heat
also...I will go get the best measurement between the said poles right now. I meant to do that anyway...but no one else seemed to not get what i was saying and saw that I used one pole as the braking point and one pole as the measuring point since I didnt have a measuring device longer than the 25 ft tape.
