3rd Gen Durango 2011+ models
2007 Durango wiper fluid fuse location
Old Oct 12, 2012 | 01:26 PM
ABJDurango's Avatar
ABJDurango
Default 2007 Durango wiper fluid fuse location
Where is the fuse for the wiper fluid pump? My wipers work but no fluid pumps and no noise like it is trying to pump. I do not have the owners manual. I see the wiper fuse, and I think they are okay, since they wipers work. Is this a common problem? What do I do next.
Old Oct 14, 2012 | 01:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Hope this helps.
Vehicle Quick Reference/Fuse Locations and Types/Specifications
SPECIFICATIONS
CAUTION: When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it suggests a problem in the circuit that must be corrected.
NOTE: If you are leaving your vehicle dormant for longer than 21 days you may want to take steps to protect your battery. You may do this by disconnecting the battery or by disconnecting the two ignition-off draw (I.O.D.) fuses located in the Auxiliary Power Distribution Center (PDC) located in the engine compartment. The I.O.D. cavities include a snap-in retainer that allows the fuse to be disconnected, without removing it from the fuse block. Pressing the I.O.D. fuse back into the cavity reconnects it.
Interior Fuses
The fuse block contains blade-type mini-fuses, relays, and circuit breakers for high-current circuits. It is located in the left kick panel. It is accessible through a snap-in cover.
Fuses (Interior)
Cavity Mini Fuse/Color Description
F1 15 Amp
Blue Instrument Cluster Battery Feed
F 2 10 Amp
Red Spare
F3 10 Amp
Red Ignition Run/Start for Next Generation Controller (NGC), Integrated Power Module (IPM), AC Relay and Fuel Pump Relay
F4 10 Amp
Red Door Node and Non-Memory Power Mirror Switch Battery Feed
F5 (2)
10 Amp
Red Airbags (2 Fuses in Yellow Holder)
F6 2 Amp
Clear Ignition Run/Start Unlock
F7 25 Amp
Natural Radio Battery Feed
F8 10 Amp
Red Ignition Run/Start for Cluster/Transfer Case/Seat Sw. Back lighting
F9 10 Amp
Red Satellite Digital Audio Receiver (SDAR)/Digital Video Disc (DVD) Battery Feed
F10 10 Amp
Red Spare
F11 10 Amp
Red Heated Mirrors
F12 20 Amp
Yellow Cluster Battery Feed
F13 10 Amp
Red Ignition Run HVAC Module/Heated Rear Glass (EBL) Relay
F14 10 Amp
Red ABS Module Ignition Run
F15 15 Amp
Blue Battery Feed Blue Tooth, Compass/Trip Computer (CMTC), Sentry Key Diagnostics
F16 20 Amp
Yellow Reconfigurable Power Outlets
F17 20 Amp Yellow Ignition Run / Rear Park Assist / Second Row Heated Seats
F18 20 Amp
Yellow Cigar Lighter Ignition
F19 10 Amp
Red Spare Fuse
F20 15 Amp
Blue Heating AND Air Conditioning w/ATC Only Battery Feed
F21 25 Amp
Natural Amplifier Battery Feed
Underhood Fuses (Power Distribution Center)
Your vehicle is equipped with an electrical power distribution center located in the left side of the engine compartment.
This center contains cartridge fuses, mini fuses and relays. A description of each fuse and component may be stamped on the inside cover otherwise the cavity number of each fuse is stamped on the inside cover that corresponds to the following chart. These fuses and relays can be obtained from your dealer.
Cavity Cartridge Fuse / Relay Mini Fuse Description
1 30 Amp
Pink Starter
2 30 Amp
Pink Front Wiper
3 40 Amp
Green Brake Batt
4 30 Amp
Pink JB Feed Acc # 2
5 40 Amp
Green Power Seats
6 30 Amp
Pink Run Remote Relay Feed
7 40 Amp
Green Blower Motor Relay Feed
8 40 Amp
Green JB Feed Acc Delay
9 Spare
10 30 Amp
Pink ASD
11 40 Amp
Green Power Liftgate ( If Equipped)
12 40 Amp
Green JB Feed / Heated Rear Glass (EBL)/ T Case Brake
13 30 Amp
Pink JB Feed RR
14 40 Amp
Green ESP Pump
15 50 Amp
Red JB Feed
16 10 Amp
Red Spare
17 Spare
18 20 Amp
Yellow Fuel Pump
19 20 Amp
Yellow Next Generation Controller (NGC)
20 25 Amp
Clear 115v Power Inverter
21 20 Amp
Yellow ABS Batt
22 20 Amp
Yellow Next Generation Controller (NGC) Batt
23 20 Amp
Yellow Trailer Tow
24 15 Amp
Blue A/C Clutch
25 15 Amp
Blue Stop Lamp Switch
26 Spare
27 20 Amp
Yellow Run/Start Relay Feed
28 Spare
29 Relay Run Start
30 Relay Run Remote
31 Spare
32 Relay Starter
33 Relay Electronic Automatic Transaxle (EATX)
34 Relay AC Clutch
35 Relay Fuel Pump Rly
36 Spare
37 Relay Stop Lamp Switch
38 Spare
39 Relay Blower Motor
40 Relay Auto Shut Down (ASD) Rly
Underhood Fuses (Integrated Power Module)
An integrated Power Module is located in the left side of the engine compartment. This center contains cartridge fuses, mini fuses and relays. A description of each fuse and component may be stamped on the inside cover otherwise the cavity number of each fuse is stamped on the inside cover that corresponds to the following chart.
1 Relay Wiper On/Off Rly
2 Relay Wiper Hi/Lo Rly
3 Relay Horn Rly
4 Relay Rear Wiper Rly
5 Relay Lt Trailer-Tow Stop/Turn Rly
6 Relay Rt Trailer-Tow Stop/Turn Rly
7 Relay Park Lamps Rly
8 10 Amp
Red Lt Park Lamps
9 10 Amp
Red Trailer-Tow Park Lamps
10 10 Amp
Red Rt Park Lamps
11 Relay Radiator Fan Hi Rly
12 20 Amp
Yellow Front Control Module (FCM) Batt #4
13 20 Amp
Yellow Front Control Module (FCM) Batt #2
14 20 Amp
Yellow Adjustable Pedal
15 20 Amp
Yellow Ft Fog Lamps
16 20 Amp
Yellow Horn
17 20 Amp
Yellow Rear Wiper
18 20 Amp
Yellow Front Control Module (FCM) Batt #1
19 20 Amp
Yellow Lt Trailer-Tow Stop/Turn
20 20 Amp
Yellow Front Control Module (FCM) Batt #3
21 20 Amp
Yellow Rt Trailer-Tow Stop/Turn
22 30 Amp
Pink Front Control Module (FCM) BATT # 5
23 40 Amp
Green Radiator Fan
24 Relay Radiator Fan Lo Rly
25 Relay Ft Fog Lamps Rly
26 Relay Adjustable Pedal Rly
27 30 Amp
Green Ignition Off Draw (IOD) #1
28 30 Amp
Green Ignition Off Draw (IOD) #2
29 Spare
30 Spare
Old Nov 15, 2021 | 02:10 PM
treii28's Avatar
treii28
Default fuse details
Yes, you can find this information in various places online. But where is any reference to the windshield washer fluid pump?
Old Nov 15, 2021 | 02:32 PM
The is a 9 year old thread. The pump is in the fluid reservoir..
Old Nov 16, 2021 | 03:00 PM
SHO Rod's Avatar
SHO Rod
The front washer is controlled via the Totally Integrated Power Module (TIPM) and unfortunately even the wiring diagram doesn't make it really clear which fuse is for the washer. I guess you kind of already realized that though. Fuse 2 (30A) is the fuse for the front wipers. I'm not sure if it also powers the washer pump though. You'll probably need to get out the multimeter or test light and start probing for voltage to the washer pump when the switch is pressed to see if the pump is getting power or not. If not, then you'd want to probe the output from the TIPM, followed by the pump request signal to the TIPM, etc.
-Rod
