3rd Gen Durango 2011+ models
Washer Fluid Light
Old Oct 19, 2012 | 07:54 PM
sonya1224's Avatar
sonya1224
Question Washer Fluid Light
My windshield washer fluid light came on a couple of weeks ago. I refilled it and about 2 days later, the light came on again. It now comes on every time I start my truck and there is fluid in the reservoir. Anyone else have this happen....any idea how to fix it?
Old Oct 19, 2012 | 09:33 PM
DJ Hellfire's Avatar
DJ Hellfire
Probably an air bubble in the sensor. Try tapping on the bottom of the bottle with the accessory power on and see if it goes out. Or try shaking the bottle a bit.
Old Oct 22, 2012 | 10:33 AM
DodgeCares's Avatar
DodgeCares
Sonya,
If the above suggestion does not work, have the dealer check it out the next time you are there. The washer fluid level switch in the reservoir can be checked by the dealer using their computer.
Old Oct 23, 2012 | 10:07 AM
sonya1224's Avatar
sonya1224
I tried both tapping the bottom of the bottle and shaking it as well. Neither one worked so I will definitely be taking it to the dealership, which sucks because I'm out of warranty and will have to pay out of pocket.
Old Oct 23, 2012 | 10:39 AM
coldsteel's Avatar
coldsteel
This may seem stupid, but have you actually activated the washer pump? Does it pump fluid? Does the warning clear?
Old Oct 23, 2012 | 07:36 PM
sonya1224's Avatar
sonya1224
Yes I have done that. The warning light is still there.
Old May 27, 2014 | 01:11 PM
Ajaxwalker's Avatar
Ajaxwalker
I have just had the same issue occur. Did you have any luck resolving the problem? The Dodge dealer said that the level switch needs to be replaced.
Old May 28, 2014 | 07:29 PM
sonya1224's Avatar
sonya1224
It actually resolved on it's own after a while. I didn't have to have anything replaced.
Old Jun 4, 2014 | 12:10 PM
Ajaxwalker's Avatar
Ajaxwalker
The warning light was showing for a about a month on my car it disappeared for a trip but then came back. I had the level sensor replaced under warranty.
Old Jun 4, 2014 | 09:35 PM
Weeg's Avatar
Weeg
Mine came on also, I replaced it myself, $2.25 part on EBAY, figured it was less of my time then going to the dealer to have it done.
