Heavy towing with the durango
Has anyone towed really heavy with the D? As in 7000lbs+? Has anyone gone over the "7400" rating?
Why I asking, is I am planning a move from CA to ND and contemplating buying a 20ft enclosed trailer. I will have plenty of time, and don't mind driving a little slower, but do you think the D could handle say 8K lbs? how about 9? I was planning on trying 8k with the trailer and another 7-800lbs in the back of the D. I would be balancing out the weight, as I am already blueprinting out layout of my furniture and whatnot, to make sure everything fits.
I'm not sure how much weight I will have. We are going to be thinning out what we have, but we still have some heavier items(washer/motorcycle/couches are on the 400lbs mark) I'm just not sure how far past the 7400lb limit I want to run it. When we moved here, we had about 10Klbs, but we have gotten a rid of a lot of things(my wood shop for one thing)
I think we have around 5-6K lbs of stuff, but add the trailer weight in, and now we are at 8-9k lbs.
Also, here is another question, the two trailers I'm looking at are both 20' trailers. Now, they have 2 different ratings(based on the axles) one of 7Klbs and the other at 10Klbs. the 7k is 3000lbs and the 10K is 3200. Should I just push a little past the limits on the 7 k to put less weight on the D, or should I get the heavier trailer, rated for the weight, but make my D pull 200 extra lbs?
Last, please don't flame on me. I know best case scenario is to pull under 7400lbs, its just not looking in the cards.
I haven't. But I've towed a 20' Airstream at 5,000 lbs, with absolutely no difficulty. A lot of folks tow way over a vehicle's stated limit, but that is done with careful attention to the hitching, sometimes including reinforcing the hitch on the vehicle. Tongue weight might be an issue, and you would certainly need a weight distributing hitch with sway control. There is a lot written about this on RV forums, I can point to to some threads is you want.
Waynead,
That would be great. I do intend on properly balancing the load as well as using a weight distributing hitch with sway control.
Hopefully I can keep it closer to the 7K mark, but I won't know until its all loaded up.
As for the second question, do you think I should buy the heavier trailer with larger axles?
Trending Topics
This place is known for setting up hitches. Check the articles under "Towing" and "Hitch Hints".
You may note that aerodynamics play a big role in handling a trailer. Airstreams, with their rounded shape tow very well. A boxy cargo hauler may be more difficult. So I'd take that into consideration when deciding which trailer to rent. Try to use one with a smaller front area that will catch the wind.
