3rd Gen Durango 2011+ models
Tire size options for stock R/T ?
Old Dec 5, 2012 | 12:34 PM
Rated R's Avatar
Rated R
Default Tire size options for stock R/T ?
Are the 265's my only option for the R/T? I'd like to go a bit wider but keep the same stock diameter.
Old Dec 6, 2012 | 10:56 AM
kingofwylietx's Avatar
kingofwylietx
To go wider, while maintaining the stock diameter, you will need a lower profile tire. Just use a tire size calculator available online and compare a few sizes in the tire model of your choice.
Old Dec 7, 2012 | 12:00 AM
GotRPM's Avatar
GotRPM
Cool
Nope. Wider tires will not work on the stock 8" rims.
Old Dec 7, 2012 | 09:25 AM
D3-Blk-Hemi's Avatar
D3-Blk-Hemi
275's would be fine on 8" wide wheels most tires have a range for wheel width. Check the manufacturer's recommendation before purchasing.
Sizes similar to Stock Tire Diameter
265/50/20 - 7" to 9" | Dia. 30.43" - Stock Tire Size
275/50/20 - 7.5" to 9.5" | Dia. 30.83" - Slightly Larger (3/8")
275/55/20 - 7.5" to 9.5" | Dia. 31.91" - 1" Taller Tire
285/45/20 - Could not find a tire available
285/50/20 - 8" to 10" | Dia. 31.22 - 3/4" Taller Tire
295/45/20 - will not fit need a 9.5" wide wheel at a minimum
Old Dec 8, 2012 | 11:49 PM
GotRPM's Avatar
GotRPM
Cool
Note that the PO wants to keep the same OD. That's 30.5", requiring a 275/45R20 tire. If you check, minimum rim width is 8.5" for that size.
BTW, better check your post. The OD on the 275/50R20s cannot be smaller than the 265/50R20s.
Old Dec 9, 2012 | 05:34 PM
D3-Blk-Hemi
275/45/20 would be 29.74" OD 1/2" smaller.
Updated must not of put the correct size in my excel program.
Old Dec 10, 2012 | 12:19 PM
Rated R's Avatar
Rated R
Thanks for the feedback. Are XL tires necessary?
Old Dec 10, 2012 | 09:53 PM
D3-Blk-Hemi
No just match or exceed the load rating. Stock is 107 (2,149 lbs)
