I come Bearing Gifts..... For Some
Yeah a little bit, the nav in the top right looks a little more streamlined and designed rather than just blocky letters and a square, it definitely did something with response time to when you touch buttons, screens are almost instantaneous and very quick to process stuff it seems now. Also i have no proof of it but i think they changed the audio processing, because it resets it back to factory middle settings, but when i put mine back to where i had it it sounds alot more crisp, and not so clunky and mid heavy. BUT the audio part could be a complete placebo affect after all the updating.
I updated mine. I too noticed that the audio is better than before more bass and crisper highs. Also the whole navigation system changed. Most of the screens are different than before. Everything seems to be working fine and in many cases better.
Just installed update all went well till system rebooted and now is stuck on software update screen. I turned vehicle off and screen stayed on. After getting desperate I pulled radio fuse and waited 5 minutes. Put fuse back in and the update started going as it should have originally. Update finished installing properly. Breathed a sigh of relief. Everything is working properly and the Nav has a different look on the input end. It is actually the same as my Dad's 2013 Jeep Cherokee so I know update is correct. A few tense moments but THANK YOU for the update.
Was it when it was doing the radio or the nav? Also i stepped away when i did mine and i didnt know it finished so quick so when i did it again i got that update error. Did you double check the software to see if it updated by hitting menu and then system information?
$*%$(#@ I tried to do the update to ver 23.whatever and now the radio will not even turn on. Tried turning car off, on, whole thing is totally unresponsive.
https://dodgeforum.com/forum/3rd-gen...1-citadel.html
yeah the info you gave me was an .iso image burned to a disc. The other one that I linked above was a data disc only but reading the forums off ChallengerTalk, JeepForum, etc every single person who responded said it worked. I will try and pull the fuse, I assume there's a schematic in the owners manual I can use to find out where it is?
Okay so i double checked that link and i think thats the sirius sat update rather then the link i provided. The one i did and you attempted was a software update not only for the HDD, the NAV and audio updates. So i think we are comparing apple and oranges. But let me look on the one link i provided. If the fuse thing doesnt work i think you can another thing to recover it
