3rd Gen Durango 2011+ models
Rear tail light out already!!!! How am I supposed to replace it?
Old Feb 14, 2013 | 09:51 AM
GizmoDurango's Avatar
GizmoDurango
Default Rear tail light out already!!!! How am I supposed to replace it?
Ok, excusing the fact that my 2012 has a tail light that is out ALREADY, when you look in the manual to figure out how to replace it, the instructions are not that good. I went out this morning and tried to pull the panel off of the rear door (because you can only replace the bulb from the inside) and that panel felt like it was welded on. I didn't want to pull it too hard because I was afraid that in the cold, something would break. Anyone have any experience replacing their rear tail lights on the lift gate?
Old Feb 14, 2013 | 10:59 AM
DodgeCares's Avatar
DodgeCares
If you PM me your email I will send you some pics that might help.
Old Feb 14, 2013 | 11:57 AM
coldsteel's Avatar
coldsteel
I hope you mean the brake/tail/turns and not the inboard parking lamp bulbs.
Been there, done that with the micro bulbs on the inboard tail lamps.
Separate the hatch trim panel from the liftgate with a trim tool and brute force.
Look inside and you can see the back of one of the 2 bulbs, the 2nd one is actually behind/inside of the metal structure of the liftgate.
I wanted to shoot the designer that thought that was a good placement.
Even if you remove the entire trim panel you still have to wriggle to get your hand back there and quarter turn the bulb to remove it at an angle.
Good luck.
Old Feb 14, 2013 | 11:58 AM
GizmoDurango
Thank you. PM sent!!!
Old Feb 14, 2013 | 12:03 PM
GizmoDurango
Good luck.
Thanks ColdSteel. I guess I need to go to PepBoys and get a trim tool. I don't want to scratch everything up
Old Feb 14, 2013 | 12:25 PM
coldsteel's Avatar
coldsteel
And Mechanix gloves, I tore the crap out of my hands doing the work without them.
Old Feb 14, 2013 | 12:30 PM
baum's Avatar
baum
hahaha... mine are out also... im just waiting for it to warm up a bit before i change it.
the other problem is the stores around me dont have the specs for the d in their computers yet so will have to take it out then go to the store to match up bulbs.
this light went out just after the turn/ brake did for me
Old Feb 14, 2013 | 04:23 PM
GizmoDurango
Right. Definitely need gloves. I think tomorrow should be in the 40s here, may can sneak and do it.
I have to go to autozone and get a trim removal kit.
I looked in the manual, and the brake/tail light bulb is a 3057. You would think that in the computer age, information would be more readily available for these stores.
Old Feb 14, 2013 | 06:25 PM
CMil527's Avatar
CMil527
This is why we need an led replacement set up...lol!
Old Feb 14, 2013 | 06:52 PM
GizmoDurango
absolutely!
