3rd Gen Durango 2011+ models
iPhone USB connector stopped working
Old Mar 2, 2013 | 11:14 PM
GizmoDurango's Avatar
GizmoDurango
Unhappy iPhone USB connector stopped working
Quick question for all of you long time D owners. My iPhone USB connector stopped working. I'm hoping that it is something as minor as a blown fuse, but I don't know if there is a separate fuse for that port (the one in the console). Anyone know?
Old Mar 3, 2013 | 01:18 AM
CMil527's Avatar
CMil527
I think I've used the port once not sure if theres a separate fuse but I wouldn't think so bro.
Old Mar 3, 2013 | 07:19 AM
jwr9152's Avatar
jwr9152
I'm not100% sure but isn't the center console usb backlit? If the light is out it may just be a blown fuse.
Old Mar 3, 2013 | 08:10 AM
GizmoDurango
Well, may be time to go to the dealer before I get a tune.
Old Mar 3, 2013 | 08:12 AM
GizmoDurango
Good point. I'll check to see if the light is still on. Thanks!
Old Mar 3, 2013 | 08:16 AM
FSTDANGO3's Avatar
FSTDANGO3
Agreed if the light is out the fuse or circuit is dead.
Old Mar 3, 2013 | 02:29 PM
bluebastion's Avatar
bluebastion
Just to add, if it is a blown fuse... it's better for you to do it yourself. Fuses are considered to be "adjustments" and will likely not be covered under warranty unless you have <12k on your ride.
Old Mar 3, 2013 | 06:57 PM
GizmoDurango
Well guys, thanks for the help...unfortunately, the light IS STILL working on the USB jack, so looks like I may have to go to the dealer.
Old Mar 3, 2013 | 07:17 PM
FSTDANGO3's Avatar
FSTDANGO3
Still look for a blown fuse
The light is actually is actually controlled from ambient lighting circuit the actual port is from another source.
STEVE
Old Mar 6, 2013 | 01:07 PM
cwilliamt's Avatar
cwilliamt
check out one of my previous posts...it describes a failed center console remote USB and the solution. It was not a fuse...there doesn't seem to be one that controls it separately. Possibly one of three things....1) disconnected from radio head unit or 2) bad wiring harness from the head to the console or 3) messed up wiring in the center console. Mine was #3. They replaced the center console lid (under warranty) and I'm good to go.
Good luck.
