3rd Gen Durango 2011+ models
Brake controller not working
Old Mar 5, 2013 | 09:10 AM
daleybread's Avatar
daleybread
Default Brake controller not working
Hi all,
I have a 2013 Crew V8 with the factory tow package. I figured it would be easy enough to install a P3 controller by using the designated wiring harness. However, the brake controller is not recognizing the trailer. Is there something else I need to do, like add a fuse? I figured it was a plug and play but doesn't appear to be.
Thanks for any help you can provide.
Old Mar 5, 2013 | 09:32 AM
CMil527's Avatar
CMil527
Hmm it should be that simple, double check your connections and the fuse. I'm sure dodgecares will chime in on this shortly!
Old Mar 5, 2013 | 10:52 AM
FSTDANGO3's Avatar
FSTDANGO3
You do have to install a fuse for that I believe.
Old Mar 5, 2013 | 11:05 AM
coldsteel's Avatar
coldsteel
Check [J03] 30 Amp Pink Trailer Tow
Old Mar 5, 2013 | 11:15 AM
DodgeCares's Avatar
DodgeCares
I cannot really speak about an aftermarket controller. The link below provides the instructions for the Mopar unit to be installed and also has a troubleshooting section that may be of some help. Click the link and then click installation guide.
http://www.mopar-accessories.com/en-...=3369&pc=82178
Old Mar 5, 2013 | 09:24 PM
raycm's Avatar
raycm
I have a 2013 Crew with V6 and tow package. I installed a Brake Controller and used the Dodge wiring harness included with the Dorango. It works and recognizes the trailer. Perhaps your trailer doesn't have the correct wiring. My travel trailer has electric brakes. I did not add a fuse.
Ray
Old Mar 5, 2013 | 09:48 PM
jnschnit's Avatar
jnschnit
I installed the factory tow package and harness. Was able to connect my brake controller with no problem and did not have to add or install a fuse.
Old Mar 5, 2013 | 11:00 PM
sinn's Avatar
sinn
I had a problem w/mine at first - pulled it back out and replaced all the wire connectors and then it worked.
