3rd Gen Durango 2011+ models
What fog lights is everybody running?
Old 03-11-2013, 07:51 AM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
Good Information.
Old 03-11-2013, 10:00 AM
Didhefocus's Avatar
Didhefocus
Didhefocus is offline
Originally Posted by pjw1967
Fog lights are placed down low and have a certain wattage for a reason. This is probably the best explanation I have seen for the proper use of fog lights. What they don't mention is that there is generally an area just above the pavement where there is little or no fog. The fog lights kinda shine under the fog layer. Yellow is better as it reflects less white light back towards the driver. So consider your responsibilities to yourself, your family, and others before you light the front of your truck up and exacerbate the problem that you're trying to overcome. http://www.danielsternlighting.com/t...fog_lamps.html
Well said!
Old 03-11-2013, 07:48 PM
BUC2303's Avatar
BUC2303
BUC2303 is offline
H16 LED BULBS work fine for the fogs they dont get hot at all and barely use any wattage plus they look great..
Old 03-11-2013, 08:06 PM
DJ Hellfire's Avatar
DJ Hellfire
DJ Hellfire is offline
Which ones do you have?
Old 03-11-2013, 08:10 PM
FSTDANGO3's Avatar
FSTDANGO3
What Brand and where did you get them?
Old 03-11-2013, 08:15 PM
BUC2303's Avatar
BUC2303
BUC2303 is offline
I'm not sure they just happened to have them at the stereo shop around me. Any H16 LED should work. You might just have to get some linemans and trim down the three pieces but that only take a second. I didn't have to trim mine but the halogens I bought before I did need to. LEDs look much better then halogens..
Old 03-11-2013, 08:43 PM
DJ Hellfire
I don't really care about the tabs. They dremel off easily. I'd prefer to not have to do it. But what's more of a concern to me is that the LED bulbs have the same polarity as the factory plug. I don't wanna have to cut my stock wiring to switch the polarity! Do you know if you had to reverse the polarity on your plug at all?
Old 03-12-2013, 02:22 AM
BUC2303's Avatar
BUC2303
BUC2303 is offline
You won't have to cut any wires at all..I wouldn't even use a dremel
Old 03-12-2013, 08:37 AM
DJ Hellfire
You remember the brand?
Old 03-12-2013, 09:12 AM
FSTDANGO3's Avatar
FSTDANGO3
X2 I am not cutting anything as well
Quick Reply: What fog lights is everybody running?
