3rd Gen Durango 2011+ models
Found 5k LED white fog light bulbs
Old 06-30-2013, 09:24 AM
PortAuthorityCop's Avatar
PortAuthorityCop
PortAuthorityCop is offline
Dreems they don't even need shaving . The lense on the bulb is too big to even fit into housing socket. Bulb needs to be thinner.
  #22
Old 06-30-2013, 09:55 AM
PortAuthorityCop
same as PHONEGUY
  #23
Old 08-02-2013, 11:07 PM
MIKEon22s's Avatar
MIKEon22s
MIKEon22s is offline
Just put these in and they look good. Had to trim 2 of the plastic tabs.
  #24
Old 08-03-2013, 07:05 AM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
Mike where did you get those I had something similar and they burned out quickly?
  #25
Old 08-03-2013, 08:25 AM
MIKEon22s's Avatar
MIKEon22s
Well VLEDS.com is where I always buy my leds had them but backordered to 8/15 so I found a set on Ebaa that looked the same, seller had good rating and 60 day warranty. We will see, had to trim 2 of the 3 tabs on bulb but snaps in fine. $36
Link PM'd not sure on forums rules of ebay links
  #26
Old 08-03-2013, 08:32 AM
woblik's Avatar
woblik
woblik is offline
I had those exact ones, one burnt out in a month and a half. Put hids in and been running them ever since
  #27
Old 08-03-2013, 08:38 AM
MIKEon22s's Avatar
MIKEon22s
I had hids in the 04 and 08 and they were great ran VVME 25 watt 5K with zero issue. Little worried about all the claims of melted housing. I am keeping the shipping box and everything just in case.
  #28
Old 08-03-2013, 09:35 AM
phoneguy589's Avatar
phoneguy589
phoneguy589 is offline
I am petty sore as long as you stay at our under the factory wattage you shouldn't melt the housing. The mistake people make are using a 55 watt kit. I had a 35 watt kit with plastic housings on my escalade ext for almost a year and no issues at all. My thing is that these fogs on our trucks don't focus light out just reflect it at a wide angle.
  #29
Old 08-03-2013, 09:46 AM
MIKEon22s's Avatar
MIKEon22s
I agree the reflector in the D3 is pretty bad, the 2007-2009 was as well, The 2004-2006 was excellent. They were like a second low beam and really lit up the road edges. I always saw the deer on the edge of the road with mine.
  #30
Old 08-03-2013, 03:14 PM
phoneguy589
I could drive down the street in my 98 I had. They should have upgraded the fogs like the headlights on the R/T's and the Citadels and put in projectors. For the price difference in the Citadel vs the R/T, the healights seem like the only upgrade compared to the base or crew. At least the R/T got you wheels, lower front valance and the suspension. Only way to tell a Citadel apart from a crew is the letters on the door and trunk....and single outlet for a V6.
Quick Reply: Found 5k LED white fog light bulbs
