Brembo BBK install / conversion 2013 durango
#52
#53
Thanks for the info and it looks great. I'm going to do this on my 2014 Durango R/T. Question for anyone with the 20x9 SRT replica wheels. Can you point me in the direction of where you purchased them and from who? I want a set in gloss black for my bright white D. Also for those who have purchased them, do they fit the hub tightly to minimize any vibrations or wobble or did you need a hub-centric adapter ring? Right now my stock wheels/tires are perfectly smooth and I'd like to keep it that way if I move to a different wheel package.
Any thoughts would be appreciated.
#57
I guess if I can get these calipers to fit my OEM wheels I'll do it otherwise I will do the upgraded cross drilled/slotted rotors and ceramic pads which I've been using on the last 2 vehicles and they work very well. I was given eBay as the place to look and buy but apparently Autoanything.com sells them as well. I've bought them from eBay the last couple of times.
http://m.ebay.com/itm/290871459040?nav=WATCHING_ACTIVE
#58
SRT reps
#60
My 2013 JGC SRT8 calipers are on order for the F/R. I bought the braided brake lines and ordered drilled/slotted rotors from R1 Concepts with Hawk HPS pads for the front and Stoptech's for the rears. I now have everything on order for the brake upgrade and should have everything within a week.
I am trying to decide on wheels since the stockers won't clear the new calipers. I'm going to see if Lorenzo WL036's can be had to fit with these brakes. If so, I'm going to go with those. If not, then I'm going to decide between 20x9 5-Star SRT8 replicas in gloss black or I may consider a 22" variation of the wheel. However I'm strongly leaning towards the 20" wheel so that I can reuse the stock tires on my 14 Durango R/T.
I'm also leaning towards Factory Reproductions for the wheels, but I will check out all of the companies listed.
