3rd Gen Durango 2011+ models
Radiator shroud removal?
Old Jul 16, 2013 | 05:39 PM
Orin500XL's Avatar
Orin500XL
Default Radiator shroud removal?
I'm trying to remove the top of the fan shroud to get access to the back of my grille to remove the nuts holding on the "Dodge" badge. I see no screw etc. Is this simply a snap-on piece, or are there some hidden latches I need to pick?
Old Jul 16, 2013 | 08:52 PM
FSTDANGO3's Avatar
FSTDANGO3
There are no nuts or screws It just snaps on there.
look carefully behind it and gently pry it off
STEVE
Old Jul 16, 2013 | 09:32 PM
CMil527's Avatar
CMil527
As Steve said it snaps in place.. Use a plastic pry tool and gently pry it off!
Old Jul 17, 2013 | 10:09 AM
Orin500XL's Avatar
Orin500XL
Thanks for the info guys.
Old Jul 17, 2013 | 11:20 AM
SLAINTE06's Avatar
SLAINTE06
I used a small tool with a hook on it. The badge has two tabs one behind the "O" and the other behind the "E". the tabs release from the bottom upward in the center of the tab. Hoep this helps, but pretty straight forward, even the paddy could it
Old Jul 18, 2013 | 02:56 PM
Fullslp's Avatar
Fullslp
Look at you Fin, giving sound advice on our Ds, good for you buddy, keep wrenching.
Old Jul 18, 2013 | 04:30 PM
SLAINTE06's Avatar
SLAINTE06
Crazy part is I have a girl I work with, we got the same 2012 RT's a few months apart, mine from dealership, she had hers built. I had a 2011 badge on mine, no hash marks, also I found out afterwards that a 2011 radio was put in also that only had the 30GB radio and not the 40GB. took allot of work, but finally had radio replaced. I had a dream the other night the hypertech was installed, but woke up and it was still in the box waiting on me for install #2.
Old Jul 18, 2013 | 05:26 PM
Orin500XL's Avatar
Orin500XL
I'm raising my sights here. I found a guy selling his used 2012 OEM chrome Citadel grille that comes with the red-stripe "Dodge" badge. If I can make the deal I'm a third of the way home. Step 2 is sneaking it past The Comptroller and Step 3 is the install -- without breaking anything. :-)
