bolt pattern and replicas
DW, Ebay sells them, Factory Reproductions sells them, and DD Mods on here sells them. They are listed for the Jeep GC. Both available in Viper reps and SRT8 reps in both 20" and 22". if your going 22's get the 9" wide not the 10's as you would not be able to rotate them to the fronts, unless you want the staggered look and don't mind not rotating your tires. I got mine used on Craigs List locally but have never seen them used for sale anywhere except that time. I was lucky and pounced fast.
Bolt pattern is expressed with two parameters: the number of bolts (DUH!) and the diameter (in MM or inches) of a circle scribed from the center of the bolt holes. For the Durango the bolt pattern is 5X127(mm), which comes out to 5 inches.
I know how bolt patterns are named, I taught vehicle maintenance for 4 years ;-)
The problem I'm having is I'm finding 2 different patterns on the interweb. I just need some one to for no siht confirm the bolt pattern so I order the correct wheels :-)
