3rd Gen Durango 2011+ models
Jack and jack stand locations
Old Oct 22, 2013 | 08:43 PM
fishandgrits's Avatar
fishandgrits
Very nice and thank you!
The pics and under car diagram are perfect!
Old Oct 22, 2013 | 09:08 PM
FSTDANGO3's Avatar
FSTDANGO3
Where do we get the pucks?
Old Oct 22, 2013 | 09:23 PM
fishandgrits
http://www.ebay.com/itm/Jacking-Pads-Lift-Jack-Pucks-for-Lifting-C5-Z06-ZO6-C6-Corvette-LS1-LS2-LS3-LS6-/151147817795?pt=Motors_Automotive_Tools&hash=item23311cab43&vxp=mtr
Old Oct 22, 2013 | 10:32 PM
FSTDANGO3's Avatar
FSTDANGO3
Thanks fishan
Old Oct 23, 2013 | 12:33 PM
V for Victory's Avatar
V for Victory
you can buy them single as well, the ones listed above are for installing and leaving installed on vettes and will not work for our trucks except on the rear lift points. I bought mine from Ebay as well and it Works!:
http://www.ebay.com/itm/CORVETTE-C5-...-/140339126077
Old Oct 23, 2013 | 12:39 PM
CMil527's Avatar
CMil527
ahhhh very nice!
Old Oct 23, 2013 | 12:41 PM
V for Victory
Used it today to put on the OEM's for the winter, also removed the MPG covers as a precaution for snow and ice build up. Ugh its so plain now!
Old Oct 23, 2013 | 02:24 PM
BadBenz94's Avatar
BadBenz94
Thank you!! I just ordered mine.
Chris
Attached Thumbnails Jack and jack stand locations-t2ec16vhjgqe9nom-knkbqpcj9r6lg-60_35.jpg
Old Oct 23, 2013 | 03:27 PM
IlliniJeeper's Avatar
IlliniJeeper
Originally Posted by pjw1967
In the last 18 months, 2 people in the Houston area have been killed by their cars falling off jackstands. One guy was 62 years old. His wife turned into the driveway to see him crushed under his old VW Beetle. Another guy, 81 years old, yes 81, was crushed by his VW bus when it fell off the jackstands. Likely they were tugging on a nut or a bolt and got the vehicle rocking. When I turned 60 (a while back) I made a promise to my wife that I would no longer go up on a roof or under a car. Moral of the story? Be real careful.
Pull off your wheels and slide them under each corner. Then, if the jack stands fail, it falls on your tires and gives you a damn good scare but at least you're still breathing.
Old Oct 23, 2013 | 04:41 PM
BadBenz94's Avatar
BadBenz94
That may work!
Im trying to think when I had all four off of the ground, but I know when I did, it was on a level surface and I always shove the car/truck as hard as I can after it is on the jack stands to make sure it's secure. Other wise it is just two at a time and the wheels are chocked and again I shove the vehicle to see if there is any movement before I get underneath or in harms way.
Chris
