3rd Gen Durango 2011+ models
shimmy @ 65mph after balance and road force
Old Dec 6, 2013 | 12:32 AM
hellomoto_25's Avatar
hellomoto_25
I'm taking my '13 in tomorrow. Not even 2k miles and I'm frustrated with the shaking in the front end. Hope they can solve it.
Old Dec 6, 2013 | 09:06 AM
FSTDANGO3's Avatar
FSTDANGO3
The factory tires will be out of balance guaranteed! And the alignment is more than likely off
STEVE
Old Dec 6, 2013 | 09:57 AM
WannaV-8's Avatar
WannaV-8
I wonder if the tires are the sole culprit. I had an MDX years back with a new set of GoodYears on it. It was "certified" so Acura had swapped out the tires. Could never get it balanced out. Finally took it to Discount Tire and they checked the "out of roundness" and found one really bad tire at 0.040" out. Changed tires and front end shake vanished. Tire guy told me that he sees a lot more factory brands being very close to unacceptable regarding out of round.
Wife's new Bridgestones had the same problem too.
Old Dec 6, 2013 | 12:57 PM
hellomoto_25
Well, got the DD back from the dealership and the shake is WORSE.
WTF!
Calling them back to see what else can be done. Frustrated!
Separate issue, they are going to replace the headliner as it doesn't line up around the hanger hooks.
Old Dec 6, 2013 | 02:46 PM
humyz's Avatar
humyz
Originally Posted by boosted20v
I'd be curious to see if 14 owners experience the same issue. I think my truck is different depending on the weather outside!! LOL
This can be true, ever notice it is harder to remove lugs in the hot Summer than the cold winter... same idea, think about how a tie rod works.
To OP, I bet your wheels are out of round. Aftermarket wheels look friggin awesome (I have em on both my Vette and Jag), but they do not have the durability of OEM wheels and will go "out of round" on you often.
Old Dec 6, 2013 | 10:38 PM
zimmer54's Avatar
zimmer54
Originally Posted by moparuser
Hello everybody, I just switched the 20' oem for a 22' set on my r/t and everything is ok but a shimmy at 60/65mph. Wheels and tires were balanced and road forced 4 times and they are ok (hunter 9700), the technician swear that the set is ok, and since he didn't sell me the set there is no interest or need to lie, besides that he didn't charge me a penny since the first time he suggested me to make it check somewhere else to have a second opinion so I took it to the dealer to find out that all parts are ok, then to Sears auto care to get it balanced once more and another guy there told me that he was thinking that the front wheels were cupping, so I did 600 miles last weekend in order to get them even. The light shimmy still there…is not a shake but a light shimmy that is gone…and back…I will really appreciate any advice or similar experience that could help me out to keep this set.
Thanks in advance.
Try Rotating Tires, work for me.
Old Dec 8, 2013 | 12:10 AM
hellomoto_25
I looked at my wheels and 2 have a ton of weight. One is on the front drivers side so I moved it to the back and most of the shake went away.
I guessing the wheels and/or tires are just not that great.
Wonder if I can get the dealership to get me something different.
Old Dec 8, 2013 | 11:37 AM
ufokillerz's Avatar
ufokillerz
no shimmy issues with my 2014 R/T, atleast not yet, fingers crossed it stays that way.
Old Dec 9, 2013 | 12:37 AM
moparuser's Avatar
moparuser
ok, now is getting interesting, I drove the truck on saturday night with practically no shimmy at all but sunday with a light shake at morning, while the hunter 9700 read everything ok under the normal parameters, I'm starting to wonder if the tires could be a reason...rims are ok, one had a small bump that was repaired and placed at the back passenger side so it is impossible and unrelated with the shimmy, but the tires while new were at my storage for a couple months, so in my humble opinion the rubber maybe could be sitting wrong or maybe a bit out of shape (thing that seem weird also since the hunter machine got them on the normal parameters) or could be changing shape because the weather...Don't know, but if there is a failure I think it must be the tires. BTW, if many of us is having this problem, what about to join voices and ask chrysler to re check the specs?
Have a great week everybody
Old Dec 9, 2013 | 11:25 AM
JRRF's Avatar
JRRF
This is a nice idea, but unless everyone is running stock tires and rims, it's a non-starter.
