3rd Gen Durango 2011+ models
shimmy @ 65mph after balance and road force
Old Apr 15, 2014 | 11:00 PM
  #31
JRRF's Avatar
JRRF
Originally Posted by salrt
OK, so I got a different explanation for the shimmy issue. Don't know about all of you, but mine is primarily when I start out and then gets better/goes away after a few miles. I talked to the folks about road force balancing them and the guy told me he would do it but it likely wouldn't fix the problem. I'm running Nitto 420s 284/40/22, so they are not cheap tires. He says the issue is the nylon cap that they put over the belts to help keep the rubber from 'wondering' at higher speeds. This nylon is apparently pretty pliable. With the weight of this vehicle, the tires tend to flat-spot when it sits for a while as the nylon cools down. This causes a shimmy until heat builds-up in the tire a the nylon gets round again.
Now, I'm no tire guy, but a buddy of mine is and he agreed. With wider more performance oriented, low profile tires, it is even more evident. So...in the words of Top Gun (yea, I'm that old), "that may be bull ****....but it's really good bull ****..."
BTW - my winter Michellin's (285/50/20, more sidewall) have no shimmy what-so-ever (not performance oriented)...further evidence that this may in-fact be true...
What this IS evidence of, and well known evidence at that, is that Nitto tires aren't nearly as good as your "tire friend" thinks they are. In reality, and particularly compared to Michellins (who make some of the best high performance tires in the business), they are basic crap. You can try and have them spun balanced on the car, but crummy tires never tend to balance correctly.
Old Apr 16, 2014 | 07:17 AM
  #32
Easyryder01's Avatar
Easyryder01
I have continental cross contact tires 285 50 R20 and they seem to have a shimmy and then it goes away. But my shimmy I believe happens after they've already warmed up. I know I don't have a crummy tire and it doesn't have a small side wall either ?
Old Apr 16, 2014 | 10:29 PM
  #33
JRRF's Avatar
JRRF
No, Continentals are not crummy. But the issue with flat spots is rarely ever seen with modern radials, and you'd need to have them sitting for a LONG time before it was ever an issue.
