3rd Gen Durango 2011+ models
Custom Exhaust is Too Loud! Help!
Old Feb 12, 2014 | 11:46 PM
  #21
robbieg25's Avatar
robbieg25
Originally Posted by humyz
I have a '14 R/T w dual exhaust and Hemi, and would like to check it out for condition of tips and rust at welds
I don't know much about mechanics or welding, but when the car was on the lift at Midas the welds looked really good and they said it looked like a very well done job. There was absolutely no rust.
Old Feb 13, 2014 | 10:26 AM
  #22
uvalmore's Avatar
uvalmore
uvalmore, what is the X-pipe the OP mentioned? Which Magnaflow exhaust is it? There are 2 on the Magna's website w dual exhaust, part # 15067 and 15068. One mentions for V6, the other mentions R/T V8. You probably got the 15067 for the V6 right?
It's an x-pipe and then a dual split and yes it was a V6. I had it installed in Vegas last July. Since you have a V8, I think you'd probably want to go with the V8 Magna Flow- I would. Robbie and I are going to meet up soon to talk about everything.
Old Feb 13, 2014 | 11:13 AM
  #23
SLAINTE06's Avatar
SLAINTE06
After having the Gibson catback installed last week, took a few days to get used to the sound, not anymore, love the ROAR. Need to attach my gopro to the back and get another video out. Wife was in it yesterday too for first time since install and loves it, but could have been feeding my ego with it being love week
Old Feb 13, 2014 | 05:06 PM
  #24
Orin500XL's Avatar
Orin500XL
An "X" pipe is exactly that -- a pipe shaped like an X. Cars with "real" dual exhaust (usually V8s) have separate exhaust pipes coming from each side of the engine, providing exhaust for each set of 4 cylinders on that side. From there, each pipe flows underneath the car to a muffler/resonator and then to the rear where the pipe exits somehwere around the rear bumper.
This method is usually acceptable for most applications but the sound can be abrasively loud and ragged because of differences in performance and pressures of each bank of cylinders. An X pipe smoothes out the noise by balancing the back pressures, which also improves performance. It is installed under the car and attached to the exhaust pipes after they leave the engine so that exhaust from both pipes flow and mix with each other then split to continue to the muffler/resonator and out the back.
Just as dual exhaust improves performance by allowing better breathing for the engine, the X pipe improves it a little more by balancing the back pressures.
It also looks cool when you do wheelies and everyone can see your undercarriage. :-)
Old Feb 13, 2014 | 06:13 PM
  #25
MoparMan1991's Avatar
MoparMan1991
Realistically you probably won't see much for gains, as you're not rolling around in an 800HP tuned racecar.
Old Feb 13, 2014 | 10:32 PM
  #26
moe7404's Avatar
moe7404
not really it only closes down 2 to 3 inches. it still came out of 2 nd gear at 125 MPH
Old Feb 14, 2014 | 08:09 AM
  #27
MoparMan1991
Of course. All of those parameters are already programmed into the computer system. Just because it did the same thing, doesn't mean your engine didn't have to work harder to do it.
