3rd Gen Durango 2011+ models
Waterpump Failure
Old May 26, 2014 | 06:13 PM
bouser's Avatar
bouser
Default Waterpump Failure
I have a 2012 Citadel with the Hemi. Had to get towed in Sat. as the pump failed and covered under hood with anti freeze. Dealer said this is the first he has seen. I have had a pump fail before they usually leak from the weep hole. This one looked like a broken Rad, hose. There is only 30k on trk. has anyone else had a problem?
Old May 26, 2014 | 07:56 PM
JRRF's Avatar
JRRF
This truly sounds like a one off problem. Could happen to anyone, but you got lucky (or unlucky as the case may be). So did the pump fail, or did the hose break?
Old May 26, 2014 | 08:23 PM
bouser's Avatar
bouser
The pump failed. in the 50yrs I have been driving I never saw one go like that.
Old May 26, 2014 | 08:51 PM
BadBenz94's Avatar
BadBenz94
It happens, bad casting who knows? I have seen many things that " never happen". Just luck of the draw. If it happened often you would see it posted. Sorry to hear about it, sounds like it's getting fixed.
Chris
Old May 26, 2014 | 09:33 PM
wildspeed's Avatar
wildspeed
Not the first one for the Durango...
Known problem from Dodge
Old May 27, 2014 | 09:04 AM
D3-Blk-Hemi's Avatar
D3-Blk-Hemi
Yep around 25k broken hose then water pump failed less than 1500 miles later.
Old May 28, 2014 | 12:46 AM
SUNBURNTsnype's Avatar
SUNBURNTsnype
Wow that sounds exactly like what happened to ours. 2012 rt. About a month ago had the seal on my pump go out. I started hearing some burbling noises coming through the firewall when the engine was running; sounded just like when your stomach growls or you get bubble guts. It was the pump sucking in air through the bad seal and trying to pump the coolant with air pockets in it. A few hours later, upon shutting off the engine, a hush gush of coolant would flow out of the seal and dump on the ground. When engine was running, the leak would taper off as the spinning shaft sealed up the leak. But then when you shut the engine off it would gush initially after shutdown then trickle and slowly stop. Only about 35,000 miles.
We were out of town and the nearest dealer was too "busy" to get us in for the repair, even as the truck was pissing coolant all over the asphalt on the service department drive up. So I said thanks for nothing, topped it off with water, drove home, keeping an eye on the temp and had my local dealer fix it under warranty.
Old Jun 3, 2014 | 12:54 AM
undertow999's Avatar
undertow999
My friend has bad his water pump replaced twice already on his 2012 Citadel Hemi
