3rd Gen Durango 2011+ models
LED lightbar functionality
Old 11-02-2014 | 02:52 PM
pieman16's Avatar
pieman16
Originally Posted by Thekoning
1. I feel like it is quite sterdy! It came with the mounting equipment and I just put some bigger washers underneith the bumper. You can grab the led bar and lift the front end up a bit with minimal flex. But definitely not towing from it well say that.
2. No issues with any sensors.
3 I took off the bumper there are forums on here how to do that and then I drilled two holes in the bumper which the bolts went through to hold it on. Ran the wire through the grill into engine bay and wired her up with a relay of course.
I highly recommend you do this led mod first the bar works amazingly well at lighting up the ~160 degrees infront of the vehicle. The 32inch curved led bars are the only ones that will fit in the bumper
http://m.ebay.ca/itm/400796978088?nav=SEARCH
Because of the grill you have to cut a bit out of the heat exchanger like I have below
Thank you sir I might be doing this. I will look around the forum on how to remove the bumper. Thanks again.
  #22
Old 01-18-2015 | 11:22 AM
Ken8600's Avatar
Ken8600
Default LED light
hi everyone
I got the 32 inch curved led bar light, but having problem to install on the front bumper. the installer said the bumper is too week for the light.
any ideals.
thank you
  #23
Old 01-19-2015 | 12:08 PM
Thekoning's Avatar
Thekoning
Originally Posted by Ken8600
hi everyone
any ideals.
thank you
The light bar is holding on fine to where I mounted it as seen in the photos on page one. Use washers on the bumper to increase strength. You have to cut a bit of the heat exchanger out to allow for the crosshair grill which extrudes out abit over the bumper.
  #24
Old 05-21-2018 | 10:46 PM
Jonathan L. Tiffany's Avatar
Jonathan L. Tiffany
Bumping this.
The link to the eBay posting is dead, but I found this instead from Amazon:
Amazon Amazon
At first glance, it seems to be exactly the same as the one you used, though the specs may be slightly different.
I just bought a 2011 DD Crew and I'm thinking of doing this mod to it, in addition to the RR lift and resonator delete.
Wish me luck!
  #25
Old 08-28-2018 | 02:46 PM
franco90's Avatar
franco90
I am doing the same mod but under the license plate
  #26
Old 09-06-2018 | 04:38 PM
franco90's Avatar
franco90
  #27
Old 09-06-2018 | 04:53 PM
franco90's Avatar
franco90
Default mine fit fine no cutting
this is where I got my light from
https://www.ultrabrightlightz.com/ub...d-scene-light/
and wiring harness
comes with all the wires and relay all wired up
https://www.ultrabrightlightz.com/ub...iring-harness/
worth the money
  #28
Old 12-04-2018 | 09:26 PM
franco90's Avatar
franco90
anyone else done this I love my light bar
  #29
Old 12-06-2018 | 03:12 PM
StormTrooperFN345's Avatar
StormTrooperFN345
looks nice! i would like to try and do the same setup but behind the main grill. Did you attempt? looks like i move the horn, just curious bc i hear its a pain to remove the grill
