3rd Gen Durango 2011+ models
Koning's Lifted Durango BUILD!
Old Nov 5, 2016 | 01:26 AM
  #101
stsalto's Avatar
stsalto
Did you have to put new shocks on with this lift?
Old Nov 5, 2016 | 01:13 PM
  #102
NateG's Avatar
NateG
You don't need new shocks with the RRO lift.
I installed the kit last weekend, and it looks great with the new wheels and tires. However, I have had a pop/clunk in , from what I can tell, the front suspension ever since I installed the kit. It's quiet driving, braking, accelerating, and turning, but when I hit a bump - CLUNK! We doublechecked everything when we installed it, and I pulled the wheels off this morning and checked everything again. Every nut and bolt that we touched was still tights. Anyone have any suggestions?
Old Nov 6, 2016 | 03:09 AM
  #103
NorCalAthlete's Avatar
NorCalAthlete
+1. Identical issue. Everything is torqued down to "german torque specs" (mechanic joke, = "gutentight"). Haven't looked up specific numbers yet but I have fairly well calibrated hands and used extra long breaker bars for some of them along with high strength loctite. Still, there's a clunk when I rock side to side when I take a speed bump at an angle, or hit a bump in the road that only affects one side, etc. Not sure what it is, haven't stuck a gopro down in there yet to see - can't really stick one to the fabric or anything.
Old Nov 6, 2016 | 01:22 PM
  #104
wdaniels's Avatar
wdaniels
I failed to mention that when tightening the sway links i took all load off the suspension by putting a jack under the lower control arm then tightening sway links and all other suspension hardware. Hth.
Old Nov 8, 2016 | 03:19 PM
  #105
NorCalAthlete
I had the whole front end up on jack stands when I was doing it.
Old Nov 14, 2016 | 04:26 AM
  #106
NorCalAthlete
Yup...lower control arm and sway bar bolts weren't torqued down enough - vibrated loose juuuuust enough to clunk. All good now, retightened everything. Wheels and tires ordered, should be here hopefully by next weekend! Not going as big as Koning or others have, I'm sticking with 265/60r18s on 18x9 fuel beasts.
Old Nov 14, 2016 | 07:18 AM
  #107
NateG's Avatar
NateG
Bingo. Spot on advice. I gave in and took it to the tire shop and told them I suspected I wasn't able to get them put back together right in my driveway. $40 and half an hour later they had me running clunk-free. Thanks for all the help guys! How about some pics?
Attached Thumbnails Koning's Lifted Durango BUILD!-before-and-after.png   Koning's Lifted Durango BUILD!-front-angle.png   Koning's Lifted Durango BUILD!-back-angle.png
Old Nov 14, 2016 | 05:09 PM
  #108
NorCalAthlete
****, $40? I had them rip apart the front end and check everything including the front diff since I popped the axles out completely when I was putting the front spacers in. Didn't have a spring compressor. Cost me $200.
Old Nov 18, 2016 | 09:39 AM
  #109
that$pit's Avatar
that$pit
Has anyone got any tips for getting the allignment right after installing the rro 2" lift?
I've taken it to 2 different shops that specialize in lifts (i live in texas, so everyones got a jacked up truck..).
Both said it was a major PITA, and firestone actually gave it back to me saying they got it as close as they could, but admitted it was barely in tolerance...
Any hidden secrets, or did you guys that have this lift just settle on close?
Old Nov 19, 2016 | 10:26 AM
  #110
wdaniels's Avatar
wdaniels
I went with close, dealer couldnt align. They did it for free, havent seen any abnormal wear yet after 10k.
