Push to Start Button
Ive been having the same problem since I bought my Durango. Sometimes it works ,sometimes not . Had to the dealer a number times and they changed the batteries on both keys , reprogrammed them . the issue went away for awhile and now its back
The RF interference can jack with the wireless keyless operations
Are you sure about that ?
Look in the glove box on the top part of it, there is a slot where usually the owner manual hide...
http://www.chryslercommercialvehicle...ngo-OM-4th.pdf
I also read somewhere that certain radar detectors can affect the push botton start something to do with interference between the keyfob signal and the dash. If you have one try removing it from the truck for a while see if you're issue goes away.
Sounds strange but I even recall installing HID lights on a Mercedes GL450 and when turned on I got interference with satellite radio if I'm not mistaken. So anything is possible.
But my first guess is it sound more like the button isn't going down far enough since you can push it to start without the actual button.
