3rd Gen Durango 2011+ models
Holy Cow! who's updated to the 50.00.07 firmware?
Old Feb 24, 2015 | 06:45 PM
  #21
plasmageorge's Avatar
plasmageorge
Originally Posted by Rocket Foot
Yeah, you can use a USB drive but you need to find a program that will burn the iso's to the USB device, just moving them to the USB wont work. I tried with Express Burn and it wouldn't do it.
If you find a program to burn them to the USB drive...make sure you put them on separate drives!
I didn't try this but here is something that might work...http://www.isotousb.com/
So I used the Free Software and got the ISO files onto my Desktop. I copied them to a DVD-R and then to a USB. Tried putting them both in the car and nothing happened.
The radio didn't recognize either....not sure how to "activate" the update.
Do I need a CD-R ?....the ISO file was 2GB, can a CD-R handle that size ?
Old Feb 24, 2015 | 08:42 PM
  #22
Rocket Foot's Avatar
Rocket Foot
I used CD-R and they worked fine...I did read somewhere that DVD-R's may not work right.
Once the system recognizes the disc, the update will run automatically. All you have to do is press YES to update HDD and YES to go from xx.xx.xx to the next version.
Old Feb 24, 2015 | 10:34 PM
  #23
roogie's Avatar
roogie
I used a CD-R as well, flawless!
roog
Old Feb 24, 2015 | 10:58 PM
  #24
2011CrewLuxSC's Avatar
2011CrewLuxSC
[QUOTE=Orin500XL;3229170]
Originally Posted by 2011CrewLuxSC
for anyone who's D is 2011-2013, I just updated to the 50.00.07 firmware and HOLY. COW. . .
the EQ is totally different . . . no dropping the Mid all the way down just to clean up the sound.
I knew the v50.00.07 would turn the screen background black . . . I decided to do them today. my RHB was on v23.xx.xx when I started so I installed the 33.01.23 and then installed the 50.00.07. . . . worked on the EQ coding
I have no freakin' idea what you guys are talking about, here. :-)
LOL. which part? the trick of taking the Mid EQ all the way down on the old software on the 430/430N and it makes the stock Alpine system sound so much better?
or the different firmware updates for the 430/430N. which is a separate unit from the 730N.
Old Feb 24, 2015 | 11:13 PM
  #25
SHO Rod's Avatar
SHO Rod
Just tonight I used the .iso files that were graciously provided by 03neonRT burned to CD-R discs using ImgBurn. I updated to 33.01.23 and then followed that up with 50.00.07 and had no issues. It doesn't even appear to have changed my radio station memories.
-Rod
Old Feb 25, 2015 | 06:39 AM
  #26
Rocket Foot
-Rod
Same here, I didn't lose any presets or any music on the HDD after the update. Burning the discs was probably the hardest thing to it...LOL!
Old Feb 25, 2015 | 08:16 AM
  #27
franco90's Avatar
franco90
I will do this this weekend. I will burn a couple of discs for those that need them.
Old Feb 25, 2015 | 05:12 PM
  #28
Orin500XL's Avatar
Orin500XL
[QUOTE=2011CrewLuxSC;3229281]
The whole thread, my friend, the whole thread. :-)
Old Feb 26, 2015 | 06:11 AM
  #29
Rocket Foot
Here is a better pic of my "new" look!
Old Feb 26, 2015 | 08:47 AM
  #30
franco90's Avatar
franco90
What is that Monitor at the bottom
